Volume difference between bridge and neck pickups - Jemsite
post #1 of 4 (permalink) Old 10-25-2011, 10:20 AM Thread Starter
X61
My Jem 77fp has Dimarzio Evolution pickups (DP158 on the neck and DP159 on the bridge). It has huge volume difference between the pickups. Despite the fact that the neck pickup is set high it sounds thin and weak. I think that there is something wrong and I'm kind of desperate because of this. I don't have any idea is it normal and how these pickups sound on other jems but this volume difference doesn't sound normal to me at all.
Any help will be highly appreciated.
(I tried to upload pictures of wiring, pickup height and soundclip of the bridge/middle/neck pickups but since I'm new to this forum I do not have permission to post links.)
X61 is offline
post #2 of 4 (permalink) Old 10-25-2011, 10:23 AM
Re: Volume difference between bridge and neck pickups
i would first go through and re solder each joint. 1 at a time
jym-ellis is offline
post #3 of 4 (permalink) Old 10-25-2011, 12:18 PM
Reviews: 3
If it sounds like a single-coil probably one of the bobbins´wire has broken. The only solution is to replace the whole pick-up if so.
vy100 is offline
post #4 of 4 (permalink) Old 11-21-2011, 02:10 PM
Yes, sounds like one coil is busted (broken coil wire inside the pickup). Have it measured at a guitar center.
Jemanized is offline
Volume difference between pickups selection hernan93 Ibanez JEM, UV, JS & Other Signature Models 8 04-11-2009 09:49 AM
Major volume discrepancy between neck and bridge pickup. Blacksunshine Ibanez JEM, UV, JS & Other Signature Models 8 12-31-2008 02:08 AM
DC resistance vs voltage, and difference bewteen neck and bridge position pickups LowYaw Pickups & wiring 4 12-15-2008 10:45 AM
Neck/Bridge Volume differences on JS eg Ibanez JEM, UV, JS & Other Signature Models 3 01-02-2008 10:00 PM
Breed neck / bridge difference in bridge position marino Pickups & wiring 2 05-25-2005 08:43 PM
HTML code is On
