Volume Pot - Jemsite
post #1 of 3 (permalink) Old 05-09-2006, 05:40 PM Thread Starter
Volume Pot
Hi Everyone, I am new here. My question is.....I recently purchsed a 2000 Ibanez Jem 7VWH and noticed that when I turn the volume pot from zero to ten, there doesn't seem to be much of an increase in Volume. I had the pot changed with a new one ( 500 k ) but still seems to do the same thing. Also new caps where installed as per the ones Ibanez shows on their wiring diagram. It seems that when I turn the volume pot from zero to 3, the voulme increase a grat deal, vut after that not much volume increase. Can anyone help me?
Thanks Guys,
johnny :-)
johnnyd529 is offline
post #2 of 3 (permalink) Old 05-09-2006, 05:52 PM
Re: Volume Pot
That seems pretty normal to me. It will usually just change the gain by changing what the pre amp gets.
Ant1981 is offline
post #3 of 3 (permalink) Old 05-09-2006, 06:07 PM
HSH
Re: Volume Pot
Sounds to me like the guitar has an audio taper pot. You can get a linear taper pot, where "5" is about half the perceived level of "10." I did that on my RG. It's now a push/push linear taper pot to split the bridge pup. Very much smoother increase in volume from 0 to 10. Just depends on your likes.
HSH is offline
bridge pup , ibanez jem , wiring diagram
Effects loop volume drop in Prosonic sanchez Gear, Equipment, Recording & Off Topic 3 05-31-2005 08:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger Ibanez JEM, UV, JS & Other Signature Models 5 03-03-2005 08:26 PM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 05:49 AM
Volume Pedals trouble311 Gear, Equipment, Recording & Off Topic 1 03-03-2004 03:23 PM
Volume pedal for Solo boost Dan D Mahnn Gear, Equipment, Recording & Off Topic 7 06-21-2003 01:03 PM
HTML code is On
