Want to replace my old Low-Pro Edge trem - Jemsite
post #1 of 9 (permalink) Old 07-04-2003, 07:05 AM Thread Starter
I want to replace the old Lo-Pro Edge tremolo on my JS1000 by the new Edge-Pro double-locking tremolo. Are they available as spare parts (nothing related on the Ibanez official website)
Karim
karibou is offline
post #2 of 9 (permalink) Old 07-04-2003, 08:08 AM
the edge pro has a different routing so i don't think you can drop it in as it is, there is very little difference in feel between both so unless you're having problems with the old bridge, leave it as it is
EXCrosslink is offline
post #3 of 9 (permalink) Old 07-04-2003, 01:06 PM
Not interchangable. The saddle inserts on the EP force the routing back about 3mm+ making it unintonateable if you tried mounting it on LP stud location.
Rich is offline
post #4 of 9 (permalink) Old 07-16-2003, 04:00 AM Thread Starter
What's the Lo-Pro Edge JS Special ?
So Lo-Pro Edge tremolo and the new Edge-Pro double-locking tremolo are not switchable... no luck.
Another question regarding Edge and Lo-Pro Edge trems which are switchable :
What is the difference between the Lo-Pro Edge "JS special"
http://www.ibanez.com/parts/default....2LE1JS37K.html
and the standard Lo-Pro Edge tremolo ?
http://www.ibanez.com/parts/default....s/2LE1R31.html
karibou is offline
post #5 of 9 (permalink) Old 07-16-2003, 04:25 AM
js lo pros come with the radius shims i believe to match the bridge radius to the js neck radius. i don't think there is any difference otherwise
post #6 of 9 (permalink) Old 07-16-2003, 07:26 AM
gitarrero's Avatar
Compared to the "standard" Lo-Pro, it seems to have a longer block which is 37mm (is this the "S" block?).
gitarrero is offline
post #7 of 9 (permalink) Old 07-16-2003, 08:07 PM
I think the 37 is the H block, S block should be 34, the HS is 31. A JS should have an HS block on it, and near all of them do. I consider anything else a mistake
Rich is offline
post #8 of 9 (permalink) Old 07-17-2003, 03:41 AM
gitarrero's Avatar
So the reason for the punched back plates on some JS's (see my other thread) might be that Ibanez ran out of HS blocks, installed longer ones and made a hole in the plate to retain pull-up capability.
post #9 of 9 (permalink) Old 07-17-2003, 10:38 AM
The hole is just "standard" on 92' and 93' models [yes even the ones with the correct block]
Rich is offline
edge trem , edge trems , locking tremolo , neck radius , pro edge , pro edge trem , pro edge tremolo , pro edge trems
Original Edge Trem - Replace the block? kigorri Tech: Setup, Repairs and Mods 4 08-19-2009 12:50 AM
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 12:22 AM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
can a orginal edge replace newer lo pro trs trem gunkungfu Tech: Setup, Repairs and Mods 4 07-14-2005 11:31 AM
Need to replace original Edge trem posts ... many questions. JohnnyRasgueado Tech: Setup, Repairs and Mods 19 04-15-2004 11:34 AM
HTML code is On
