Weird pickup thing. Is it normal? - Jemsite
 5Likes
  • 1 Post By Dankrad
  • 2 Post By aesthyrian
  • 1 Post By peromucho7
post #1 of 14 (permalink) Old 11-29-2020, 06:53 PM Thread Starter
Hello!! I bought this guitar jem bfp a few months ago and didn't realize that this plastic thingy from the pickup raising up could not be normal. Is it? Also, if I raise the pickup itself, it tens to raise only from one side instead of raising even.
Dankrad is offline
post #2 of 14 (permalink) Old 11-30-2020, 04:07 AM
Re: Weird pickup thing. Is it normal?
It is normal,
If we think to same thingy, it is screw that can go in or out and its purpose is to even string to string output.
If one string is too loud or too quiet you can adjusted output with that screw. Some pickups have one or both coils with non adjusting thingies like your midle pickup.
Answer to other question is that pickup cable can sometimes pull pickup down or push up. So make shure that pickup cable is free to move with pickup by opening back cover.
peromucho7 is offline
post #3 of 14 (permalink) Old 11-30-2020, 03:15 PM
I have had pickups that didn't stay even too... I put small pieces of foam under them to keep them even when adjusted.
FireEagle is offline
post #4 of 14 (permalink) Old 11-30-2020, 06:50 PM Thread Starter
Thanks for the idea!
FireEagle likes this.
Dankrad is offline
post #5 of 14 (permalink) Old 11-30-2020, 06:53 PM Thread Starter
Originally Posted by peromucho7 View Post
It is normal,
Thanks. Is there a tutorial somehwere to help me how to do that?
Dankrad is offline
post #6 of 14 (permalink) Old 12-01-2020, 04:46 AM
post #7 of 14 (permalink) Old 12-01-2020, 11:05 AM
Learned it from someone more experienced than I... probably from this site. Just passing it on! Good luck!
post #8 of 14 (permalink) Old 12-03-2020, 10:42 AM
its just an adjustable hex screw, grab yourself an Allen wrench and adjust it to your liking
DeadLord is offline
post #9 of 14 (permalink) Old 12-04-2020, 10:33 AM Thread Starter
Read it but it only talks about the screws that adjust the overall height and not those specific black nobs. Besides, they don't seem to have like a hole for a screwdriver
Dankrad is offline
post #10 of 14 (permalink) Old 12-04-2020, 06:08 PM
I think someone needs to play their guitar more and look at it less.
peromucho7 and Jemerator like this.
aesthyrian is offline
post #11 of 14 (permalink) Old 12-06-2020, 03:20 AM
That's what I am thinkig all time.
aesthyrian likes this.
post #12 of 14 (permalink) Old 12-07-2020, 04:13 AM
First advice. If you do not know what is allen key, or pole screw in humbucker,
it is better not to adjust it by yourself until you gain more experience. You can make more damage then benefit.
Here is tutorial.
Find the biggest allen key that can fit into the hole.
Turn clockwise to screw in or anticlockwise to screw out.
Plug your guitar to preferably clean sound with least amount of compresion and listen string to string volume. If most of the strings are about same level and one string is too loud or too quiet you can adjust it by this procedure.
But if I am at your place I would not bother.
Just play.
You have great guitar.
Find tabs of your favorite song that you dont know how to play.
And when you learn it, your guitar will sound much better the before.
post #13 of 14 (permalink) Old 12-07-2020, 06:16 AM Thread Starter
Here is tutorial.
Just play.
I ended up figuring it out! I just didnt know the name of that part. I had a set of allen keys and was able to move it. I still don't know much of polepieces, but it seems that one has a function of angling the pickup. Could that be possible? (Ive been playing for years...this is just my first good guitar)
Dankrad is offline
post #14 of 14 (permalink) Old 12-09-2020, 07:50 PM
No, the pole pieces give the magnetic field a path to the strings (the magnet sits under the 2 coils and in-between the rows of pole screws). The pickup height is handled by the 2(usually 2) screws at the top and bottom(below the pickguard). Any tilt can be due to a few things(some pickups have 3 or 4 height screws that can also control tilt) including how the springs or foam sit under the pickup(most Ibanez models with pickups screwed directly into the body, will have 2 strips of foam under the pickup). Next time you have all the strings off, unscrew the 2 screws that are deep inside(where the pickguard has those small half-circle cutouts above and below the pickup) and lift the pickup out and all will become very clear. Most "hot" pickups use allen screws as the pole pieces, but some use a blade, and others(Gibson) use screws on one coil and slugs on the other. Do the different poles change the sound? I don't know. You might also check out youtube for some videos about humbucking pickups for more info.
HTML code is On
