Whammy bar help! - Jemsite
post #1 of 14 (permalink) Old 12-24-2006, 09:30 PM Thread Starter
Unhappy Whammy bar help!
My whammy bar is way loose. and i dont want ot have to spend 15 bucks for a new bar because they wont sell me the new bushings seperete/. and tighting the screw under the tremelo doesnt helo. ive read the tech section on IbanezRules.com. i tried that d'addario package trick that i think JJEMMER77 told me. but i dont know how to do it properly. are there any other tricks of the trade i can well... trade? thanks
AmazinAzian12 is offline
post #2 of 14 (permalink) Old 12-24-2006, 11:15 PM
Re: Whammy bar help!
Take the bushings off and put nail polish/tape on the groovs and put them back on.That usually keeps it stiff for a while.
iPig is offline
post #3 of 14 (permalink) Old 12-24-2006, 11:28 PM
There is a NUT underneath that is usually the culpret, unfortunatly you have to take the trem out to tighten it. It takes a 10mm wrench, but it's worth it.
GTR-MAN is offline
post #4 of 14 (permalink) Old 12-24-2006, 11:38 PM
Youll have to fix the bushings and the nut because they are both problems in themselves and the bar will still be loose unless both are taken care of.
crevis is offline
post #5 of 14 (permalink) Old 12-25-2006, 12:17 AM Thread Starter
the nail polishy thing works perfectly. all that was wrong was the bushings being old. even tho its a brand new guitar. hmmm. well now i know what helps
post #6 of 14 (permalink) Old 12-25-2006, 01:43 AM Thread Starter
ok. would super gluing the grooves on the bar, letting it dry and then replacing the washers help also. or like hot glue. would that work to add more lift on the washers to help the bar stay tight?
post #7 of 14 (permalink) Old 12-25-2006, 03:35 AM
Hot glue is a good idea.
TommyGuitar is offline
post #8 of 14 (permalink) Old 12-25-2006, 03:50 AM
personally i prefer using PTFE tapes
madpickin03 is offline
post #9 of 14 (permalink) Old 12-25-2006, 12:22 PM Thread Starter
Hmm PTFE? i dont know what that is.
I need pics, or maybe vids on how to do these tricks. and if rich could make a video fo doing the normal way of removing the trem and tighting the nut. i cant do anything by reading instructions. i have to watch to learn.
thanks
Asian
sorry if this makes me look demanding
post #10 of 14 (permalink) Old 12-25-2006, 12:39 PM
JJEMMER777's Avatar
+1!
If you want to FIX the problem. The d'addario package is just a quick fix but it works well.
If you're not comfortable with removing the trem yourself, just bring it back to the shop you got it at. Sam Ash I'm guessing???
JJEMMER777 is offline
post #11 of 14 (permalink) Old 12-25-2006, 04:14 PM Thread Starter
Originally Posted by JJEMMER777 View Post
+1!
yea. or ill take it to a guitar repair shop across the street from my local guitar center
post #12 of 14 (permalink) Old 12-29-2006, 08:10 PM
i've tightened the nut on the back of my trem but its still loose
Dragon Slayer J is offline
post #13 of 14 (permalink) Old 12-30-2006, 05:08 PM Thread Starter
yea mine too. i dont think that it is the nut that needs tightening for me. i tried and the nut wont tighten anymore. im thinking this is all a bar problem. ill ask the guitarr tech to look into it for me.
post #14 of 14 (permalink) Old 12-30-2006, 06:52 PM
Exclamation Re: Whammy bar help!
Thanks for that info! It just so happens that I recently bought a deep-well 10mm socket and it's deep enough to catch the nut as-is: I didn't have to take the vibrato (tremolo) out to do it. I just moved the vibrato enuf to get the socket on it (may have to put the whammy bar on it and dive it some) and it worked. It might be a good idea to take the "bar tightening spring" off the shaft to be sure it doesn't get damaged. I did that to all 5 of mine and it worked like a charm.
This is a much better way to get the vibrato tight. I used to get a straight screwdriver and try to screw it tighter from the top of the unit. Not a great way to do it.
While I was at it, I put some little strips of foam rubber under all the springs to stop them from vibrating.
HTH.
David Tetlow
mystery is offline
local guitar center , sam ash
FS: Digitech wh-1 original whammy pedal SilverSurfer2 Classified Ads: Guitars and Gear 5 04-29-2010 08:44 AM
WTT Black Edge whammy bar for a Black Lo TRS whammy bar RG_76 Classified Ads: Guitars and Gear 5 07-11-2006 06:03 PM
Changing Whammy settings Freaker Tech: Setup, Repairs and Mods 0 05-27-2006 06:27 AM
Alternatives to the Whammy? hexa-db Gear, Equipment, Recording & Off Topic 12 09-04-2003 03:28 AM
Which Whammy is better? - how does the reissue compare to th Soloist Gear, Equipment, Recording & Off Topic 3 04-19-2002 12:50 AM
HTML code is On
