What floyd does my guitar have? - Jemsite
post #1 of 18 (permalink) Old 11-02-2009, 04:31 PM Thread Starter
Hey everyone I'm kind of new and wanted to learn a bit about my guitar.
I got it second hand for 1100
The serial is F0035xxx
What year was it made then?
Also judging by the year what kind of floyd does it have.
Lo-Pro Edge or just an edge.
Thanks guys
kylendm is offline
post #2 of 18 (permalink) Old 11-02-2009, 04:46 PM
Re: What floyd does my guitar have?
Post a picture if you can.
bluffalo is offline
post #3 of 18 (permalink) Old 11-02-2009, 04:59 PM Thread Starter
Here you go
and another question. Does anyone know how to fix a stripped strap hole?
I had a show and I was tossing my guitar around and it just stripped right out. Luckily I caught it and finished the show fine but this is a real downer :/
kylendm is offline
post #4 of 18 (permalink) Old 11-02-2009, 05:11 PM
Have a pic of the headstock? Just for curiosities sake...
Jack Secret is offline
post #5 of 18 (permalink) Old 11-02-2009, 05:22 PM
Its a Lo-Pro EDGE. Pretty much as good as it gets
bluffalo is offline
post #6 of 18 (permalink) Old 11-02-2009, 05:22 PM
Hub
To answer your question, it is a 2000 with a Lo-Pro Edge
Hub is offline
post #7 of 18 (permalink) Old 11-02-2009, 05:37 PM Thread Starter
Thanks everyone
Now can anyone help me out as far as my guitars strap hole?
kylendm is offline
post #8 of 18 (permalink) Old 11-02-2009, 05:39 PM
Reviews: 18
instead of fixing the hole you could probably put the strap button on the back of the horn
IBNZ_RG is offline
post #9 of 18 (permalink) Old 11-02-2009, 05:56 PM Thread Starter
Yeah, I might do that. But then there will be a big gap in the horn.
I have some mahogany wood filler. If I filled it all the way down and drilled a hole when it dries could that work?
kylendm is offline
post #10 of 18 (permalink) Old 11-02-2009, 05:57 PM Thread Starter
I'll post in Tech spot maybe I'll get other answers.
kylendm is offline
post #11 of 18 (permalink) Old 11-02-2009, 06:01 PM
satchbooger's Avatar
For a quick fix some wood glue and toothpicks.
satchbooger is offline
post #12 of 18 (permalink) Old 11-02-2009, 06:57 PM
What he said
jemboyee is offline
post #13 of 18 (permalink) Old 11-02-2009, 07:13 PM
Reviews: 21
yep, thats worked for me too!
UV-7-BK is offline
post #14 of 18 (permalink) Old 11-02-2009, 10:11 PM
Ayrton's Avatar
That hole is a little big for the old toothpick trick. You really need to drill that out and plug it.
Use a drill bit that is just larger than the hole, and drill down about 1". Plug the hole with a matching hard wood dowel (from your local home center), and then re-drill the appropriate sized hole for the strap button screw.
If you do all this correctly, the strap button will cover most of the chipped paint, and it will be fairly unnoticeable.
Ayrton is offline
post #15 of 18 (permalink) Old 11-04-2009, 07:52 AM Thread Starter
Ok thanks guys
Do you know what type of wood the neck is made out of?
kylendm is offline
Can a neck for a Floyd Rose guitar go on a non floyd guitar? Mattycake All Other Guitars (including Prestige) 3 11-12-2008 03:54 PM
Floyd Rose Guitar w/ OFR newbieguitarmaker All Other Guitars (including Prestige) 18 04-16-2007 04:32 PM
Floyd Rose Pro on an RG470 or other TRS guitar martyfriedman86 Tech: Setup, Repairs and Mods 16 09-26-2006 08:06 AM
Problems with floyd on my ibanez guitar! Jeff - CRO Tech: Setup, Repairs and Mods 2 06-01-2006 06:51 AM
Did any JS guitar ever come with an Original Floyd? themaidenmaniac Ibanez JEM, UV, JS & Other Signature Models 7 12-10-2005 05:31 PM
HTML code is On
