What is the JS2PRM Phase Switch? - Jemsite
post #1 of 5 (permalink) Old 05-22-2011, 10:31 PM Thread Starter
What is it actually do for the sound?
Hendryhz is offline
post #2 of 5 (permalink) Old 05-23-2011, 04:40 PM
Contributor
OCDemon's Avatar
Re: What is the JS2PRM Phase Switch?
Without the detailed explanation of out of phase which I can't do justice to, it slightly thins out the sound and gives it a bit of a different tonal quality. Someone else can explain what putting the pickups out of phase from each other means.
OCDemon is offline
post #3 of 5 (permalink) Old 05-24-2011, 07:21 AM
Reviews: 4
IIRC it's kinda like the strat sound, right? so you can simulate RW/RP with a HH?
fwd0120 is offline
post #4 of 5 (permalink) Old 05-24-2011, 07:34 AM
I can tell you what a phase switch does.
The phase switch puts the pickups out of phase with each other by effectively wiring one of them backwards.
What this does for the sound is all the frequencies that are common to both pickups i.e. the bass frequencies will cancel so you are left with the bridge pickup treble content only, no bass.
This gives a characteristically thin quality to the sound.
because the pickups are placed at different points on the string, the cancellation is not perfect.
In the case of a strat even though the pickups are wired in phase, the different positions means that some of the frequency content cancels and you get that position 2 and 4 "honk".
jim
Vim Fuego is offline
post #5 of 5 (permalink) Old 05-24-2011, 10:23 PM Thread Starter
Wow, thx a lot you guys...
I still get a little bit confuse, but I got a general idea about it. May be I need to heard it by myself that I can understand the different.
Hendryhz is offline
phrase switch
My diagram for HH with series/parallel and phase switch isn't working... CA_Dan Pickups & wiring 2 05-27-2010 11:37 PM
JS100 Upgrades - Phase Switch jmbjsx2000 Ibanez JEM, UV, JS & Other Signature Models 17 08-23-2009 06:36 AM
wiring phase switch JohnnyRG1527 Pickups & wiring 2 11-28-2008 05:38 AM
Phase switch? Myst and rain Pickups & wiring 2 12-16-2007 12:42 PM
Phase vs Phase shifter Ant1981 Gear, Equipment, Recording & Off Topic 13 02-09-2006 06:56 AM
HTML code is On
