When does Joe use the coil Tap and High pass filter? - Jemsite
post #1 of 12 (permalink) Old 09-24-2009, 06:22 AM Thread Starter
Just curious to know.
I'm again GASsing tremendously for a JS. I used to own one in the days I didn't know how to handle that Formula1, and I didn't have the impression that especially the High pass fiilter did something for me.
So please, enlighten me here
Silverburst is offline
post #2 of 12 (permalink) Old 09-24-2009, 09:51 AM
Reviews: 59
Re: When does Joe use the coil Tap and High pass filter?
I think the best recent example of those features would be Come on Baby from Satchifunkulous. Most of that song has one or both engaged. In my own experience, the coil tap obviously makes a huge difference in tone and volume from off to on with most set-ups and settings. The high pass filter doesn't do much unless your volume is rolled back. It is MUCH brighter when engaged if your volume is down around "3" or so. Conversely, if you have the volume dimed, you won't really notice any change.
smooth55 is offline
post #3 of 12 (permalink) Old 09-24-2009, 01:36 PM
The JS is a great instrument, in some ways superior to the Jem in my opinion. In terms of electronics, the high-pass filter is pretty much always engaged on mine. I usually play with the volume knob all the way up, at which point, the filter makes no detectable difference at all. Set up that way, the volume knob almost becomes more of a gain control, wherein rolling back the volume results in a cleaner sound with a bit less volume but a very similar overall tone. With the neck pickup on, high-pass filter engaged and volume rolled back to somewhere in the 30-50% range, the guitar sounds so Satch-like, it's frightening.
djohns74 is offline
post #4 of 12 (permalink) Old 09-24-2009, 02:54 PM
Based on how my ears hear it, I would say that the solo on the song Super Colossal is either recorded with the neck pick up coil tapped or it was recorded on a Stratocaster's neck pick up.
RedTiger is offline
post #5 of 12 (permalink) Old 09-24-2009, 03:10 PM
Many songs on the new Chickenfoot CD, he is using it.
nato101010 is offline
post #6 of 12 (permalink) Old 09-24-2009, 03:52 PM Thread Starter
Hmm, interesting, thx!
post #7 of 12 (permalink) Old 09-24-2009, 10:37 PM
I always engage the high pass filter when I use the split coil switch, it just makes it more musical and usable.
guitarnoize is offline
post #8 of 12 (permalink) Old 09-26-2009, 12:18 AM
The volume knob cleans up your tone on all guitars, hi-pass or not.
littlephil is offline
post #9 of 12 (permalink) Old 09-26-2009, 02:12 AM
Yes, but usually you lose tone. With the high pass filter you can keep your tone and clean it up a bit.
A good example of this is when satch plays Always With Me Always With You. He lowers the volume knob a great deal to clean up the intro.
yellowshirtguy is offline
post #10 of 12 (permalink) Old 09-26-2009, 04:56 PM
Reviews: 59
I wouldn't say you lose or gain tone with the filter. You lose or gain treble, and engaging the filter makes it brighter and crisper. For me, sometimes I want that, sometimes I don't.
smooth55 is offline
post #11 of 12 (permalink) Old 09-26-2009, 06:19 PM Thread Starter
I just went to get a JS1200 I had been keeping an eye on for a while. And indeed, the high pass filter makes much more sense now. It clears up the tone at lower volume settings indeed, and like smooth55 says, it gets crispier again.
Now hat strikes me again is the lower output the Fred seems to have. I really digg the typical (slightly nasal some people call it, I find it to have some kid of mouth harmonica tone to it), but I find that I need to turn the gain up on my amp/pedal settings quite a bit to get in the higher gain kinda tones Satch uses on lots of occasions. (easier to end up with a mudier tone). Have you guys bumped into these problems and how did you deal with it ?
post #12 of 12 (permalink) Old 09-28-2009, 12:52 PM
Reviews: 59
I would adjust my pick-up height if I felt like I needed to up the output but didn't want to add too much gain from external sources. Still, there are some other factors like your amp settings that will play heavily into things. Sometimes just a touch of EQ goes a long way and I usually find that I simple adjustments to any part of the signal chain require total re-tweaking of everything else to compensate and adjust to what I want to hear.
smooth55 is offline
coil tap , high pass filter , js1200
High pass filter help northlander30 All Other Guitars (including Prestige) 9 01-18-2009 01:30 AM
High Pass Filter guitar425 Pickups & wiring 5 05-30-2007 08:33 AM
High Pass Filter ZeroDrift Ibanez JEM, UV, JS & Other Signature Models 3 01-27-2005 03:18 AM
Where can i get a high pass filter Blackstrat86 Ibanez JEM, UV, JS & Other Signature Models 17 03-16-2003 11:16 PM
Jem high pass filter question wireman24 Ibanez JEM, UV, JS & Other Signature Models 5 06-09-2002 03:48 AM
HTML code is On
