where can I get the trem posts for the Edge trem? - Jemsite
post #1 of 7 (permalink) Old 03-17-2005, 03:50 AM Thread Starter
rx
one of my posts is busted, I need a new one. where can I get a couple and which brand does it have to be? can it be any licensed floyd rose trem post? also, how do I restore the knife edges on the trem itself? I really wanna get my divebombs going! thanks
rx is offline
post #2 of 7 (permalink) Old 03-17-2005, 04:16 AM Thread Starter
rx
Re: where can I get the trem posts for the Edge trem?
ok another question...... Ibanezrules.com has 3 types of trem posts.... "Old design 92'-00'", "redesigned - grooved", and "EP-non-locking". which one do I need for this Edge Trem from 1999?
thanks
rx is offline
post #3 of 7 (permalink) Old 03-17-2005, 04:28 AM
E-mail Rich and say what exact model you have (if it's 99 it sounds like it should be a lo-pro) and ask which posts you need, that's what I did.
Artist is offline
post #4 of 7 (permalink) Old 03-17-2005, 10:35 AM
Old design - same thing that's in your guitar.
Redesigned - same stud but with the V opened up for freer movement and truer returns.
EP studs - non locking junk pulled out of new guitars and replaced with locking studs.
Rich is offline
post #5 of 7 (permalink) Old 03-17-2005, 03:36 PM Thread Starter
rx
so i should get the redesigned studs for more $$$?
rx is offline
post #6 of 7 (permalink) Old 03-17-2005, 05:00 PM
Your choice, not mine. There's a reason they cost more. The old design are studs I took out of new guitars to replace with good ones.
Rich is offline
post #7 of 7 (permalink) Old 03-17-2005, 08:24 PM Thread Starter
rx
Question Re: where can I get the trem posts for the Edge trem?
here are pics of the problem.....
in this picture, you can see the stud chipped on the top. I can't adjust the height to do setups anymore, and currently the post is too deep in the body that the trem knife edge lifts up from the studs when I'm pulling up.
second pic.....
in this picture, the trem is not aligned in the routing. it's a bit on the right side, and the right side is closer to the nut than the left side. it is more noticeable if you look at where the fine tuners are..... the right side is almost touching the body, while the left side is far from the body.
third pic....
in this picture, you can see the trem block is a bit crooked, and the right spring is crooked
would replacing the trem studs fix this problem? thanks
rx is offline
edge trem , floyd rose , floyd rose trem , locking stud , locking studs , trem block , trem studs
Wtd Edge trem posts. Zoot Classified Ads: Guitars and Gear 2 03-12-2011 09:07 AM
Upgrading Edge 3 Trem Posts. Livingparody Tech: Setup, Repairs and Mods 2 03-08-2011 07:45 PM
bad trem posts?? on new edge Pro?? adamcbest All Other Guitars (including Prestige) 6 10-09-2004 06:56 PM
Edge trem posts x2 required earthman Tech: Setup, Repairs and Mods 2 11-27-2003 07:34 AM
Edge trem with trs type posts stratman219 Tech: Setup, Repairs and Mods 1 10-12-2003 08:03 AM
HTML code is On
