Why not 2 curved Edges on a Trem knife? - Jemsite
post #1 of 7 (permalink) Old 01-10-2008, 08:30 PM Thread Starter
Question Why not 2 curved Edges on a Trem knife?
Why do Ibanez use One Straight and one Curved Edge on the Tremolo Knives?
Why not Both Curved? Like Floyd Rose.
Seems mostly to be durability problems with a straight knife edge.
A round holds better, I gather.
Also: Have anyone Replaced the Knives on a Ibanez trem?
Harris sells spare "Knife Edge Sets", so it should be possible.
Metallion is offline
post #2 of 7 (permalink) Old 01-10-2008, 09:08 PM
Re: Why not 2 curved Edges on a Trem knife?
Well, that's a pretty easy one to answer - if both knife edges were curved, the post spacing would have to be incredibly exact, and incredibly consistent from guitar to guitar, otherwise the trem wouldn't sit correctly on the studs - one curved knife edge effectively locks the lateral position of the bridge and stops it from moving sideways, while the straight knife edge allows for a little bit of inconsistency and error in the positioning of the posts.
I don't know if the curved edge is more durable or not (as both knife edges ina perfect world would kiss the post on exactly one atom....), however i would imagine it is harder, hence more costly to machine a good curved knife edge than a straight one.
David McCarroll is offline
post #3 of 7 (permalink) Old 01-11-2008, 03:22 AM
Tank's Avatar
Reviews: 65
From a physics point of view you are correct, the one angled edge will leave better margin for little errors in the post alignement.
Also stability is an issue. The straight line beneath stabilizes the knife edge and it should be more durable and hold its "sharpness" longer.
But thats theory, we see that both work fine...
Tank is offline
post #4 of 7 (permalink) Old 01-11-2008, 10:15 AM
Are you saying that Ibanez dont have the CNC equipment or skills to produce accurate post holes? ;-)
chris101 is offline
post #5 of 7 (permalink) Old 01-11-2008, 10:18 AM
Pfft, knife edges are so 80s... ball bearings, people!
Speaking of 80s... I had a guitar with high-end Schaller trem, and the knives were actual insets of hardened steel... The rest of the bridge was other material.
That thing lasted forever.
My LoPro Edge never failed me either, but you could see a big wear-mark on the straight edge.
I've heard a lot of horror stories about Lo-TRS and other cheaper trems that get dull really quickly because they use cheap and soft metal for the knife edges, completely ruining tuning stability and all. But I've never used any of those. I've only used the Schaller, the LoPro Edge, and the ZR-7 for a prolonged period. No complaints on any of them, but the ZR sure looks coolest
Scali is offline
post #6 of 7 (permalink) Old 01-16-2008, 05:11 PM
Reviews: 7
Sure they are capable of doing it, anyone with a cnc is. It's just easier and less costly/time consuming to just make one knife edge find home.
brothersnowgone is offline
post #7 of 7 (permalink) Old 01-16-2008, 05:29 PM
Ibanez don't manufacture the TRS, they are generic and sold to many guitar companies so I imagine it would be for inconsistancies between guitar manufacturers.
crevis is offline
david mccarroll , floyd rose , ibanez trem , pro edge , schaller trem
RG3120TW Trem grinding Aeivan All Other Guitars (including Prestige) 5 02-04-2006 11:58 AM
Maintaining trem stud grooves? giannifive Tech: Setup, Repairs and Mods 0 09-15-2005 05:21 PM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 05:37 PM
Edge Trem question LegacyMan Tech: Setup, Repairs and Mods 1 10-21-2003 05:20 PM
Lo-pro knife edges: one weared, one not...what to do? Pesso Tech: Setup, Repairs and Mods 3 11-08-2002 05:32 AM
HTML code is On
