Why not the Lo-TRS? - Jemsite
post #1 of 14 (permalink) Old 12-24-2013, 11:03 AM Thread Starter
Why not the Lo-TRS?
I recently picked up a used '99 JS100 that I've been gradually replacing all the chrome hardware with black. The '98 JS100 came with the Lo-TRS II trem and, after a LOT of research on this forum, it seemed to be universally reviled, with many people opting to replace it with a Gotoh 1996T Floyd due to the "drop-in" replacement process. I don't want to mess with routing to get an Edge to work so "drop-in" replacement is of utmost importance to me.
While monitoring eBay for a deal on a black Gotoh, I came across a used a black Ibanez Lo-TRS for a song. Again, after researching it and weeding through all the misinformation, I figured it couldn't hurt to buy it and see how it compared to the Lo-TRS II. Long story short, I couldn't be happier with it and am perplexed why the Lo-TRS gets lumped in as a junk trem with the Lo-TRS II? It is made in Japan and has a screw in arm that screws directly into the block similar to a fender trem and is completely stable, no play in the arm, and returns to the correct position after significant wammy exercising. My only complaints are that I needed to shim the saddles to match the neck radius and it does need a bigger sustain block as it sounds a little thin but I'll get that replaced in time (needs to be custom made due to the screw-in arm).
Is it's only crime sharing a common name with the Lo-TRS II? What are others real-world experiences with the Lo-TRS? I'm not looking for hearsay but actual issues I may come across because it seems like a hidden gem to me (no pun intended).
Jamvan is offline
post #2 of 14 (permalink) Old 12-24-2013, 01:25 PM
Reviews: 4
Re: Why not the Lo-TRS?
I have a lo-trs on my ex series. it works great. stays in tune well. the only things i do to it is, put chapstick on the studs where the knife edge on the trem contacts it to cut down on the friction and i use some teflon tape on the threads of the studs to help lock the studs down due to the fact that there is no locking screw in the center of the stud like on the studs for an edge trem.
jl2556 is offline
post #3 of 14 (permalink) Old 12-24-2013, 01:26 PM
RGTFanatic's Avatar
Your absolutely correct. The original design TRS and Lo-TRS are very good trems. They are stable and dependable.... especially with a locking stud mod.
RGTFanatic is offline
post #4 of 14 (permalink) Old 12-24-2013, 05:22 PM Thread Starter
I'm just getting back into playing after many dormant years (kids, work, life, blahblahblah) and this is my first Ibanez. This site and Rich over at Ibanezrules.com have been invaluable in information to help upgrade this guitar. I've replaced the stock AH pickups (PAF Joe, Mo' Joe) and tried (unsuccessfully) to install a push/pull volume pot with a high pass filter. I will say unequivocally that I hate to solder and am not very good at it.
As such, I'll take the lubrication into account for the trem edge as well as possibly retrofitting some locking studs if the need arises.
Jamvan is offline
post #5 of 14 (permalink) Old 12-24-2013, 06:00 PM
Yup the Lo-TRS is a good trem unit. Same basic knife design and just as good as an Original Floyd IME... Pick up some Teflon Tape for the studs and it will be even better...
Swirltop is offline
post #6 of 14 (permalink) Old 12-25-2013, 10:29 AM
I think most will agree that the Lo-Trs I is ok and that the II is the one to avoid. I don't recall reading much hate mail against the I only the II.
moebius is offline
post #7 of 14 (permalink) Old 12-26-2013, 04:45 AM
Lo-Trs I is a very good tremolo and stays in tune
mtc777 is offline
post #8 of 14 (permalink) Old 02-01-2014, 12:16 AM
Bump!
I picked up a nice condition LO-TRS I from a fellow jemsite user and didn't realize the studs and inserts are smaller than the LO-TRS II. =\ How bad off am I going with the LO-TRS II studs and the LO-TRS I knife edge? I have heard the LO-TRS II studs are crap. Is there another stud that would fit into the LO-TRS II insert?
Kinda bummed, was hoping for a direct drop in!
Thanks,
Steve
justaguy_99 is offline
post #9 of 14 (permalink) Old 02-01-2014, 02:13 AM
RGTFanatic's Avatar
Originally Posted by justaguy_99 View Post
Bump!
Thanks,
Steve
The difference in diameter between the two studs should be minimal and easily corrected through intonation.
Can you give specifics about your guitar? (year, model, etc.) Pics of the two studs next to each other would be helpful too.
post #10 of 14 (permalink) Old 02-01-2014, 03:26 AM
It's a Mid-90s JS100. Serial # C 5072301
The original LO-TRS II stud is on left, the LO-TRS I stud is on the right:
Appreciate the help, thank you.
Steve
post #11 of 14 (permalink) Old 02-01-2014, 08:13 AM
Attachment 4279
Steve
The studs you have look better to me honestly... Thicker with finer threads. Hard to tell from the pic, but they don't look beat up...
Screw them in to about the height they would be at for the bridge to function and try wiggling them. If there is a ton of play they will be crap, if they don't move you should be good. If there is some minor play there wrap the threads with teflon tape.
Then just drop the TRS II in and try it out...
Swirltop is offline
post #12 of 14 (permalink) Old 02-01-2014, 01:51 PM
I think OFR also uses those with finer thread ...
mtc777 is offline
post #13 of 14 (permalink) Old 02-01-2014, 03:02 PM
They don't look that beat up to me, but the knife edges on the old trem sure were. How does one tell if there's too much play? They move around a bit in the insert, maybe 1mm? Is there any concern about the harder TRS I knife edges and the presumably softer Korean TRS II studs?
Great community here, thank you!
Steve
post #14 of 14 (permalink) Old 02-01-2014, 08:42 PM
Steve
I would wrap the studs with teflon tape and try them out. It's not like the knife edges are going to lop off the top of the studs
If it stays in tune nice I'd be happy and play the hell out of it. If the tuning stability isn't what you'd like then I'd probably look into some Gotoh or Floyd studs and anchors
My guess is the studs you have will be fine though...
Swirltop is offline
js100 , lo-trs , replacement , trem , tremolo
HTML code is On
