Will a 22 fret Prestige 540 neck fit the JS100? - Jemsite
post #1 of 5 (permalink) Old 01-23-2009, 10:15 PM Thread Starter
Still looking for a replacement neck. Thanks
dirkdiggler is offline
post #2 of 5 (permalink) Old 01-23-2009, 11:03 PM
jb4674's Avatar
Reviews: 18
Re: Will a 22 fret Prestige 540 neck fit the JS100?
Call Rich.
Jimmy
jb4674 is offline
post #3 of 5 (permalink) Old 01-24-2009, 01:49 AM
I believe that the JS guitars have sqare heel neck joints not AANJ. If the neck you found is from a newer Prestige S540 it will probably have the new AANJ heel. I think an S540 neck from an old guitar would fit (1987-1991 era) but I heven't tried it so you must check it first. The main difference would be the neck profile (thiner on the S) and the angled headstock on the S versus the Strat style one on the JS.
jazzedout is offline
post #4 of 5 (permalink) Old 01-24-2009, 07:41 AM Thread Starter
I forgot to mention it's a square heal 540 neck.
post #5 of 5 (permalink) Old 01-25-2009, 10:52 AM
You may have to plug and re-drill the screw holes in the neck
and sand the heel a bit thinner or widen the neck pocket on the
body a small bit, but apart from that, it should fit.
You will need a new nut, since the S neck is 1mm wider than the
JS neck. You'll also need new tuners, unless you want to mess
with the 540 headstock, since the way the tuners are mounted
on the JS100 is different to the way they're mounted on higher
end models (including the 540).
btw, unless I missed something, if it's a square heel neck it won't be a prestige.
horstausmforst is offline
js100 fret issues callen3615 Ibanez JEM, UV, JS & Other Signature Models 21 01-04-2009 10:43 PM
22 fret S-series neck swapped with a 24 fret RG neck? Clydefrog All Other Guitars (including Prestige) 4 07-27-2007 02:11 AM
Prestige Neck in a js100? guitar425 Tech: Setup, Repairs and Mods 1 04-18-2007 08:32 PM
Replacing 21 fret neck with 22 or 24 fret neck Jing Tech: Setup, Repairs and Mods 4 01-12-2006 03:35 AM
Fret quality on Prestige neck? lloop9 All Other Guitars (including Prestige) 5 09-27-2004 10:12 AM
HTML code is On
