Will a Jackson 24 fret Neck fit perfectly on an ibanez body? - Jemsite
post #1 of 3 (permalink) Old 09-18-2006, 12:58 PM Thread Starter
Hey guys.. i've just purchased a jackson 24 fret neck and since im not really diggin the jackson body type .. will an ibanez body not the AAJN fit a jackson neck without problems?
thanks
infoworx is offline
post #2 of 3 (permalink) Old 09-18-2006, 01:12 PM
Re: Will a Jackson 24 fret Neck fit perfectly on an ibanez body?
You might try searching for whether you can replace jackson necks with fender necks, or put jackson necks on fenders. The old square heel Ibanez necks fit on fenders and vice versa, so by the transitive property of equality you should be able to swap ibanez and jackson necks, if jacksons fit a fender.
slugman is offline
post #3 of 3 (permalink) Old 09-18-2006, 03:24 PM
It really depends on the neck... er, and the body. For instance, an older pre-AANJ RG550 body takes a 24 fret neck where the fretboard extends past the heel for a few frets. If you try to attach a 24 fret neck where the heel is (relatively) flush with the end of the fretboard, it won't intonate correctly without modifying the neck or the pocket.
Demiurge is offline
fret neck , ibanez neck , ibanez necks
putting a jem neck on rg body *theanimal*05 Ibanez JEM, UV, JS & Other Signature Models 18 04-21-2006 10:21 AM
Ibanez RX 22 Fret Neck, Do They Fit a Standard Strat Pocket? CrossingStar All Other Guitars (including Prestige) 0 09-15-2005 09:32 AM
FS- Ibanez PGM30 paul gilbert neck, and EKG body MorbidAngel Classified Ads: Guitars and Gear 9 02-18-2005 07:25 PM
will an Ibanez 7 string neck fit a jackson Ibanut All Other Guitars (including Prestige) 7 10-04-2004 12:14 AM
Original Bolt On neck put on AANJ body? Rich? - is it possib Captain Ron Ibanez JEM, UV, JS & Other Signature Models 2 01-19-2002 10:10 PM
HTML code is On
