Will a Lo-Pro fit into an Edge III body? - Jemsite
post #1 of 4 (permalink) Old 04-07-2010, 05:55 AM Thread Starter
Title says it all pretty much, I got a Lo-pro need a body and there's a 350 on **** it says it takes an Edge 3 trem, will my lo-pro fit?
Cozi101 is offline
post #2 of 4 (permalink) Old 04-07-2010, 09:44 AM
Re: Will a Lo-Pro fit into an Edge III body?
I don't believe it does. Check this thread out: http://www.jemsite.com/forums/f21/ed...olo-68062.html
Look into Original Floyd Rose or an Edge Pro.
Andrius is offline
post #3 of 4 (permalink) Old 04-07-2010, 11:42 AM
Reviews: 21
Without any modification, no it will not fit.
I had to route out the back end and sides of the trem cavity with a dremel to make a lo-pro edge fit into the edge pro 3 spacing on a Xiphos.
The actual lo-pro edge block will fit the gap that the bottom of the block sticks through, just not quite the width and the length of the trem cavity. I didn't have to take much off, just shaved a few mm off the wood so the trem could move nicely.
It takes a mod, a steady hand and a little bit of time.
Good luck if you're gonna do it, I'm sure if someone like me can you could manage it
D1m3b4g2 is offline
post #4 of 4 (permalink) Old 04-07-2010, 01:14 PM
Vin
is it worth doing a jem project with a 350???
I love my 350, but for a project wouldnt it be better buying an alder jem-style body?
Vin is offline
lo-pro edge 3
Original Edge trem on RG-470 body radter Tech: Setup, Repairs and Mods 5 12-22-2008 09:54 AM
EDGE II in JEM body. Deep Tech: Setup, Repairs and Mods 6 07-16-2004 11:58 AM
JEM body with EDGE II tremolo Deep Ibanez JEM, UV, JS & Other Signature Models 2 07-15-2004 02:21 PM
How do you get the Lo pro edge inserts out of the body? SilverSurfer2 Tech: Setup, Repairs and Mods 12 01-29-2003 11:01 PM
HTML code is On
