Zero Resistance - Jemsite
post #1 of 10 (permalink) Old 07-20-2006, 07:50 PM Thread Starter
Zero Resistance
i would like to make a mod to my js1000 like the Zero Resistance tremolo system does anyone have any suggestions.
johnboy30230 is offline
post #2 of 10 (permalink) Old 07-21-2006, 12:54 AM Thread Starter
Re: Zero Resistance
how about a tremsetter? would i still be able to do dives up and down or will that fix the bridge.
post #3 of 10 (permalink) Old 07-21-2006, 01:06 AM
Re: Zero Resistance
I would like to know that as well
jimbojim is offline
post #4 of 10 (permalink) Old 07-21-2006, 04:47 AM
Re: Zero Resistance
A tremsetter doesn't fix the bridge unfortunately, it merely stiffens up the tremolo.
I'd suggest looking at a tremol-no which can fix the bridge, allow it to only dive, or be fully floating.
Andelusion is offline
post #5 of 10 (permalink) Old 07-21-2006, 11:28 AM
Re: Zero Resistance
A ZR trem would require substantial routing. Best look at another option ;o)
guitarsalad14 is offline
post #6 of 10 (permalink) Old 07-21-2006, 03:00 PM Thread Starter
Re: Zero Resistance
i was checking out some vai stuff turns out he has a setup aclled the ibanez backstop. however they dont make it anymore or something but esp make something similar rich used to sell it but he says hes out it was some thing like an arm adjuster
post #7 of 10 (permalink) Old 07-21-2006, 06:25 PM
Re: Zero Resistance
Actually the tremsetter can be adjusted to its highest point of tension and the bridge is almost fixed (the bar is also almost unusable at that point)
sniperfrommars1 is offline
post #8 of 10 (permalink) Old 07-22-2006, 01:04 PM
Re: Zero Resistance
Yea the esp arming adjuster will solve the non return to neutral when you yank and dive the bar and also provide counter tension for in-tune double stop bends.
post #9 of 10 (permalink) Old 07-22-2006, 09:11 PM Thread Starter
Re: Zero Resistance
im not trying to fix the bridge i like being able to go either direction with my whammy bar however im looking for more stabability so i can change tunings with out having to readjust the bridge everytime
post #10 of 10 (permalink) Old 07-22-2006, 11:59 PM
Re: Zero Resistance
Just try getting better at restringing and try finding new tricks etc...then it won't be such a tedious task, rather enjoyable for some strange reason
Ozzdoc is offline
esp arming adjuster , ibanez backstop , tremolo system , zero resistance trem
DC Resistance and Millivolts BiggieAL Pickups & wiring 5 05-09-2006 10:45 AM
output vs DC resistance amateur_guitarist Pickups & wiring 4 09-17-2005 10:08 PM
Powersound Dc resistance rickyk All Other Guitars (including Prestige) 1 04-26-2005 05:16 PM
Need DC Resistance numbers for V2 pickup!!! freewheeler Pickups & wiring 0 07-12-2002 11:28 PM
Volume & Tone Pots - Measuring the resistance? (or whatever bduersch Tech: Setup, Repairs and Mods 4 12-24-2001 12:18 AM
HTML code is On
