02 RG570L Issues and Info! - Jemsite
post #1 of 6 (permalink) Old 03-07-2006, 09:18 PM Thread Starter
I just picked up a 2002 RG 570L MIJ. This is my first post 91 Ibanez and well, it's been at least a couple years since I've even had any Ibanez guitar. While I absolutely love how the guitar plays and looks, I've ran into a couple problems. After I got it, the first thing I did was yanked the TRS bridge and dropped in a Gotoh lic. Floyd I had sitting around. Here's problem #1. The string lock screws are to long. If I go to intonate properly, the screws hit the back edge of the trem route. Routing the guitar is not an option at this point and I absolutely will not go back to the TRS bridge. I also tried and OFR w/ the same issue.
Anyone know where I can find someone to make shorter lock screws?
The other issue I'm having is the hardware. It has the powder cosmo H/W on it, the gotoh is flat black. Not jiving together at all. Tuners and knobs will be cake to find, I'm concerned w/ finding a locknut that matches the fretboard radius in black. Anyone have any ideas?
Normally this stuff would be crawling out of the woodwork, but I'm a lefty, so that makes it a bit more complicated.
I'm also interested to know a little bit more about these guitars. Are they good quality? I read somewhere that they were the predecessor to the prestige 1570L. Is that true?
Thanks for any input guys!
The Furious One is offline
post #2 of 6 (permalink) Old 03-07-2006, 09:29 PM
Re: 02 RG570L Issues and Info!
I believe you'll find it's a 470L or lower. No 570 ever had a TRS on it.
Rich is online
post #3 of 6 (permalink) Old 03-07-2006, 09:40 PM Thread Starter
Sorry for the confusion then. It's stamped 570 on the neck heel so I just took that as the model # of it. I bought it used so there is the possibility that someone pieced it together....
post #4 of 6 (permalink) Old 03-07-2006, 09:46 PM
What was the body stamped?
Rich is online
post #5 of 6 (permalink) Old 03-07-2006, 10:02 PM Thread Starter
I'll check that out tomorrow. I have to take it apart again to shim the neck pocket. I'll even snap some pix off!
post #6 of 6 (permalink) Old 03-07-2006, 10:33 PM
warmoth has locking nuts
http://www.warmoth.com/hardware/part...de_string_nuts
I just replaced the lo-trs II on my S470L a couple weeks ago with a lefty OFR. not sure where u can find shorter screws for the floyd, maybe try e*** for a used trem and use the parts from that
mikethedigimon is offline
fretboard radius , locking nut , locking nuts , string lock , trs bridge
WTB: Ibanez RG3120TWL (also considering RG570L and/or RG2550L) freewheeler Classified Ads: Guitars and Gear 1 11-13-2012 07:07 PM
FS: IBANEZ RG570L LEFTY BLACK LennyX Classified Ads: Guitars and Gear 0 11-15-2008 04:54 PM
JEM 77B RMR Issues CHAOSREX Ibanez JEM, UV, JS & Other Signature Models 13 08-12-2007 12:26 PM
8 strings: the info - Info please mojo All Other Guitars (including Prestige) 12 03-07-2006 06:10 PM
Amp issues Sypher Gear, Equipment, Recording & Off Topic 3 02-27-2003 09:34 PM
