22-fret Ibanez neck on Ibanez RG? Can I? - Jemsite
post #1 of 18 (permalink) Old 09-28-2007, 12:08 AM Thread Starter
I've got an 80s RG with the square neck joint. The frets has been giving me major buzz, and it just will not go away with truss adjustments alone. The best I can do with it is raise the action and play uncomfortably.
But, I've got a good spare Ibanez Proline neck with an ebony fretboard. It's 22 fret and I want to know if it's a problem? I've had it on the RG body once already, and it plays better than the original 24 fret neck. I did a quick measure of the scale lengths from each neck, from the nut to the center of the 12th fret, and they both are equal.
So I want to know if my intonation is going to be off balanced? Is this going to work?
Stygian is offline
post #2 of 18 (permalink) Old 09-28-2007, 12:21 AM
Dee
Re: 22-fret Ibanez neck on Ibanez RG? Can I?
I don't see why not. It's the same scale length, it should be fine.
Dee is offline
post #3 of 18 (permalink) Old 09-28-2007, 12:32 AM Thread Starter
Yeah, I mean it'd be great if I could. I'm playing the guitar now, and it's bad. Now, the 24 fret neck has that overhang, so I know the 22 fret Ibanez Proline neck is going to leave a space, but I honestly don't think it looked too bad this way when I tried it.
So I know it's physically possible. I just want to be sure it won't sound bad tonally.
Stygian is offline
post #4 of 18 (permalink) Old 09-28-2007, 12:33 AM
whoa hold up, the scale length is correct but if it previously had a 24 fret neck, and you're putting on a 22, ie 22 will be where 24 was. then you're essentially moving the entire neck towards the guitar and you'd need the bridge to move also, to keep the scale length.
on a 22 fretter the bridge will be placed closer to the tail than on a 24(of same scale).
so in intonation terms, sorry mate it won't work.
edit just saw you have an overhang- and the 22 doesn't? if so it may be close enough to work. just remember scale length has to be correct enough between bridge saddles and nut.
Ki swordsman is offline
post #5 of 18 (permalink) Old 09-28-2007, 12:35 AM
Ayrton's Avatar
With the same scale, you will be just fine.
I have swapped strat necks (21 vs 22 fret) necks in the same fashion.
Ayrton is offline
post #6 of 18 (permalink) Old 09-28-2007, 12:43 AM
yeah it all depends how close it is and how much room to be adjusted the saddles have..
post #7 of 18 (permalink) Old 09-28-2007, 12:47 AM
The 2 extra frets on the old school square heel 24 fret necks were fingerboard extensions.
The neck pockets and scales should be the same, and you should have no problem.
mike-o is offline
post #8 of 18 (permalink) Old 09-28-2007, 01:20 AM
Dee
It'll work fine, only it'll look a bit funny.
Dee is offline
post #9 of 18 (permalink) Old 09-28-2007, 03:56 AM
On ANY guitar or bass etc.....
Measure from nut to middle of 12th fret
Double it - thats your scale length
on an RG its 12 3/4 inches to the 12th = 25.5inch scale
you can put any neck on any guitar
AS LONG AS : nut to 12th = 12th to bridge saddle
Then all you're left with is the cosmetic appeal - or not
Max
ibanezking is offline
post #10 of 18 (permalink) Old 09-28-2007, 05:51 AM
aah cheers! well that's the key point then. in that case if they're the same length neck but with the extra 2 as fretboard hang, it'll be perfect.
post #11 of 18 (permalink) Old 09-28-2007, 09:09 PM Thread Starter
Thanks guys confirming that the neck switch would work. I painted the blank space black and put the Ibanez Proline 22 fret neck on it today. I think it looks pretty good (not perfect), considering it has some nicks and the pickups are far from original anymore. It's been heavily modded.
The Ibanez Proline neck has a larger logo and is straight rather than angled, so it isn't the camera playing tricks. Although, the spot I painted REALLY shows up in a photo for some reason, maybe its the flash. I'm not sure I'll keep it this way, but it's nice to play on a neck without the buzz, and an ebony fretboarded guitar is ALWAYS a plus!
Stygian is offline
post #12 of 18 (permalink) Old 10-09-2007, 05:35 PM
I'm thinking of something similar. What model and year was your proline with the ebony fretboard?
I know one of the rare JS models (I think the JS90) had an ebony fretboard... what other necks/modes had ebony fret boards that would be compatible wit this neck joint or the AANJ?
thanks!
Oatman is offline
post #13 of 18 (permalink) Old 10-09-2007, 07:18 PM
If you were to take the guitar into a decent set up tech he/she should be able to level the frets and adjust the neck to get rid of the excess buzzing. I did it with an old RG and it cost me justy $65 and it plays better than ever.
guitvai1 is offline
post #14 of 18 (permalink) Old 10-11-2007, 04:38 AM Thread Starter
thanks!
It was from a 1985 Pro Line. Aside from the funky look of the gap between the edge of the fretboard and neck pickup (not bad in real life), it plays well. It's definitely fatter than the original wizard neck, though! I notice I can't play quite as fast. I honestly don't know what other necks had ebony, but all the ones I've seen thus far have had the old square neck joint or were neckthru. I think they've all been Pro Line guitars too, some with different inlay or even binding.
Stygian is offline
post #15 of 18 (permalink) Old 10-11-2007, 04:43 AM Thread Starter
Good idea, but I'm really cheap and don't know anybody locally that can do this work. Aside from that excuse, there may be a problem beyond the frets, because they do not look that worn down to me. Maybe my neck is out of whack beyond what a truss rod adjustment can fix? Anyways, I might play switcharoo with the necks a few times, but for now the replacement works!
Stygian is offline
bridge saddles , ebony fret board , ebony fretboard , fret board , fret neck , fret necks , neck joint , neck pickup , neck pockets , rod adjustment , scale lengths , truss rod , truss rod adjustment
WTB Ibanez RG neck square heel prefer maple fretboard ricky_lee Classified Ads: Guitars and Gear 0 07-05-2007 07:44 PM
Enquiring about 2nd guitars GuitAust Vendors, Auction & Reseller Talk 27 09-24-2006 09:40 AM
Ibanez RG thru neck in the UK Davey Classified Ads: Guitars and Gear 14 01-07-2006 11:06 AM
A/B test between Ibanez RG7421 and Schecter 007 Blackjack Mind Riot All Other Guitars (including Prestige) 23 12-06-2004 01:12 PM
