7-String project question.. - Jemsite
post #1 of 7 (permalink) Old 03-09-2008, 03:16 PM Thread Starter
that hopefully can get answered ASAP, like hopefully soon after i post this.... im working on a project, the body was an old 7420, i filled in the neck pup cavity, and also turned it from a trem-routed guitar to a fixed bridge.. but i got a nice deal on a '07 1527 neck with a locking nut.. now you can see where im going.. so my question finally is, does a neck work on a guitar that will have just a fixed bridge? (sorry if its a dumb question, but im not sure so I might as well ask)
Thanks!
~Mike (TGR)
ibanezrocker61 is offline
post #2 of 7 (permalink) Old 03-09-2008, 04:56 PM
Re: 7-String project question..
I believe the 1527 neck is a tad bit wider than the 74/7620 necks as well. Not sure about the nut. I'm sure it wouldn't hurt it but I think you'll have to shave a bit of the neck pocket to get that 1527 neck in there. I think someone posted about it a ways back. They ended up ruining the body because they messed up the pocket trying to get the neck to fit...
TMatt142 is offline
post #3 of 7 (permalink) Old 03-09-2008, 05:37 PM
why not, paul gilbert did? he just left the lock down pads off of the nut. as far as mating the 2 parts together, that i am unsure of.
rich
rty13ibz98 is offline
post #4 of 7 (permalink) Old 03-09-2008, 05:51 PM Thread Starter
yea i noticed that too... i did route a little off from the neck pocket to fit the 1527 neck in there, so it fits nicely now... so final answer, the neck with the locking nut should work with a fixed bridge?
Thanks for the replies guys!
~Mike
post #5 of 7 (permalink) Old 03-11-2008, 05:55 PM
i dont see why it wouldnt work. Isnt the mtm1 a fixed bridge with a locking nut?
-Matt
guitardevil2005 is offline
post #6 of 7 (permalink) Old 03-11-2008, 07:18 PM
itll work fine, in fact those locking nuts not locked are less restrictive than a tight fitting corian nut
i heard somewhere u can get a compensating nut that bolts right up to a floyd nut route
also u can actually use a really sharp chissel and just take out the routed section from the end of the locking nut section out to the neck, and glue in a tall corian nutt and cut and shape it down....maybe..?
losgatosrg350dx is offline
post #7 of 7 (permalink) Old 03-13-2008, 07:56 AM
As said, it will work fine, BUT, you will not be able to lock it, as otherwise you won't be able to get in tune without lots of swearing (like the early floyd rose systems....)
7 Dying Trees is offline
fixed bridge , floyd rose , locking nut , locking nuts , neck pup , paul gilbert
7 String gauge question.... nosferatu123 All Other Guitars (including Prestige) 31 03-19-2011 01:01 PM
prestige 2027 seven string wiring question brainstem3000 All Other Guitars (including Prestige) 4 04-15-2008 06:13 PM
String tension, noob question no1spretty All Other Guitars (including Prestige) 15 06-02-2006 05:04 AM
changing string action quick question FireAndSpirit Tech: Setup, Repairs and Mods 4 10-04-2005 11:13 AM
EBMM Petrucci 6 string question Scott 74 All Other Guitars (including Prestige) 1 05-12-2005 08:58 PM
