.70 strings in a Lo Pro Edge - Jemsite
post #1 of 13 (permalink) Old 01-30-2006, 07:07 AM Thread Starter
Hello,
whats the maximum string gauge which fits into a Lo Pro Edge trem?
Does there fit a .70 ?
Thanks a lot.
Mike
rgk7 is offline
post #2 of 13 (permalink) Old 01-30-2006, 10:26 PM
Re: .70 strings in a Lo Pro Edge
a .70 will fit. You may need to drill out the tuning peg though, as I've had problems fitting the string through in one or two of my guitars.
7 Dying Trees is offline
post #3 of 13 (permalink) Old 01-30-2006, 10:44 PM
WOW... 70? you must have some toned fingers
ChopTart is offline
post #4 of 13 (permalink) Old 01-30-2006, 11:57 PM
A .70 will fit no problem, you will have to reintonate your guitar for it though. 7 dying trees is right with the drilling of the tuning pegs as it will not accomodate the thick string without widening it. If you don't want to drill it, you can also just use several thick guitar strings and use it to file the inside(I did it with a .56 and a .62 before moving up to the .70 to file it)
buddroyce is offline
post #5 of 13 (permalink) Old 01-31-2006, 12:58 AM
Use Zakk Wylde's GHS Boomers which use .70s as a low E I believe on a 6. I can't go for the mismatched tensions, but I have usd .13-.58s in the past on a 6.
red5 is offline
post #6 of 13 (permalink) Old 01-31-2006, 01:27 AM Thread Starter
Hi again,
actually itīs not for me.Maybe I try it one day.
I already use 10-60.Zakk Wylde...Thats enough for me... :-)
Thanks a lot
Mike
rgk7 is offline
post #7 of 13 (permalink) Old 01-31-2006, 03:47 AM
Reviews: 7
I must be the only person that uses those in B, I prefer super thick strings for my 7. I usually just buy an extra .10 to make them a 7 set, real meaty
brothersnowgone is offline
post #8 of 13 (permalink) Old 01-31-2006, 10:18 AM
This is tuned to A mind you, although I'd still use 60-65 if i tuned it to B as i found the low string really benefits from that extra tension. I then use a 10-52 (or9-46 if in standard) set
post #9 of 13 (permalink) Old 01-31-2006, 11:24 AM
Am I the only one crazy enough to use the GHS 10-60 with a .70 on my 7 string tuned Bb? (ok.. I just realized I kinda am nuts, so ignore me.. )
post #10 of 13 (permalink) Old 01-31-2006, 02:35 PM
i use 10-52 with a low .70 on my 7 string tuned to B standard. I just can't stand floppy strings, the .70 gives me just the right tension. I think it actually matches the tension of the .52 tuned to E quite well.
AARRGGHHH is offline
post #11 of 13 (permalink) Old 01-31-2006, 02:47 PM
Hey whatever works for you. Just to confuse people I am going to use all .20s. Probably have to tune it like a sitar or something else.
When I had 13-58s, people would ask "can I play your guitar?" I'd tell them "you can try if you want!" and they'd try to play a chord, fail and give it back
red5 is offline
post #12 of 13 (permalink) Old 01-31-2006, 04:17 PM Thread Starter
yeah thats right Iīve heard this so often!Ha!
The only guy who was able to play it like that was my drummer...I asked him if he was sure for going with drums
rgk7 is offline
post #13 of 13 (permalink) Old 01-31-2006, 04:54 PM
But I am talking about on a 6!
red5 is offline
edge trem , pro edge , pro edge trem , tuning pegs , zakk wylde
My Lo Pro edge keeps breaking strings keith_remy Tech: Setup, Repairs and Mods 5 11-11-2010 03:59 PM
Edge Trem and .10-.52 strings (yes...) saTa Tech: Setup, Repairs and Mods 20 01-04-2008 04:19 PM
Edge Pro Strings to tight Led_Fingers Tech: Setup, Repairs and Mods 15 06-27-2005 02:48 PM
Replacing Strings on Edge Pro GlassPrison2112 Tech: Setup, Repairs and Mods 2 10-27-2004 01:53 AM
Edge pro 7 strings felipennn Tech: Setup, Repairs and Mods 5 12-02-2003 11:11 AM
