90's USRGs - straight headstock? - Jemsite
post #1 of 5 (permalink) Old 11-13-2001, 07:35 AM Thread Starter
I was contemplating those 90's USRGs (w/PBC truss-rod) on Jemsite catalog section and my eyes get hooked on those exotic models with flamed tops.
My questions are:
- Are they straight headstock?
- Why the retainer bar is literally attached to the Top-Lok?
Thanks
nuno
nuno is offline
post #2 of 5 (permalink) Old 11-13-2001, 11:32 AM
Jason Stone's Avatar
90's USRGs
It's not a straight headstock, but the angle is nowhere near the same as the angle on other RGs. *
The retainer bar is not attached to the top lock, it's just behind it. *The headstock on the USRGs is actually completely separate from the neck and is actually detachable. *I remember seeing an auction on eBay about a year ago where the idiot seller had actually locked the strings down at the nut and then removed the headstock permanently to "Steinbergerize" his guitar. *The joint where the headstock and neck meet is a brass plate and the string retainer bar is attached to that plate.
The USRGs are fine guitars, but the headstock angle and the proximity of the string retainer to the nut make tuning these things a pain in the a$$. *The reason is that you cannot lower the string retainer bar enough to make the strings sit flat in the nut before you lock them down. *As a result, when you lock the nut, everything goes way sharp. *To compensate, you have to screw down the fine tuners at the bridge and then back them off once everything is locked down.
J
Jason Stone is offline
post #3 of 5 (permalink) Old 11-14-2001, 06:57 AM Thread Starter
90's USRGs
Jason Stone: ...the headstock on the USRGs is actually detachable... *
...WHAT?!?
Are you serious???
nuno is offline
post #4 of 5 (permalink) Old 11-14-2001, 10:17 AM
site founder 0% owner
jemsite's Avatar
90's USRGs
do a forum search for more details on the USRG and tension-free neck... glen
jemsite is offline
post #5 of 5 (permalink) Old 12-17-2001, 06:03 AM
gitarrero's Avatar
90's USRGs
nuno on 11:57 am on Nov. 14, 2001
...WHAT?!? Are you serious???
Hard to believe, but it's true!
gitarrero is offline
retainer bar
WTB: Ibanez USRGs, Hamer Californian & Chapparal Ambitot Pu Phang Classified Ads: Guitars and Gear 5 12-12-2009 10:27 AM
WTB: Ibanez USRGs, Hamer Californian & Chapparal Ambitot Pu Phang Classified Ads: Guitars and Gear 5 06-29-2008 07:31 AM
WTB: Ibanez USRGs, LACS, 540S7, Hamer Californian & Chapparal Ambitot Pu Phang Classified Ads: Guitars and Gear 2 08-13-2007 05:39 PM
WTB/WTT: Ibanez 540R, Gambale, J Custom, USRGs & many more! [email protected]@K Foe Classified Ads: Guitars and Gear 6 09-04-2006 10:39 AM
Is this a USRG30?? - Only USRGs has tension free necks? alienasia All Other Guitars (including Prestige) 19 03-03-2002 03:18 AM
