'92 rg550 fixer upper - Jemsite
post #1 of 3 (permalink) Old 12-10-2017, 10:02 PM Thread Starter
I can't figure out how to post the pictures but I picked up a 92 rg550 at a pawn shop for $130. It only had two strings strung up and the Floyd rose was missing a few set screws . It doesn't have a back plate , the tremelo bar wiggles loose slightly (appears to be a loose nut) and to top it off the action is off and the higher notes buzz . Oh also they put a matte grey finish over the electric blue on the body but left the headstock alone. For 30$ I got it strung up, everything screwed in , ****ef with the action and plugged in and it's still buzzing on the high notes . It sounds like it's almost coming from my neck humbucker or possibly the single coil , just a slight buzz . The relief looks just fine but I haven't done a whole lot of this before. I'm wondering if anyone has experience fixing a buzz on these rg series. Never had an Ibanez before , all Jackson . Figured the tremelo on the bitch was almost worth 130$ so I had to grab it . Hopefully it turns out to be a sweet little shred stick , any advice would rock . Again I wish I could toss these pictures on but I cannot figure it out baha . Thanks
Speednfeed is offline
post #2 of 3 (permalink) Old 12-11-2017, 07:05 AM
Re: '92 rg550 fixer upper
My 89 RG750VP has some noise from the pups coming through the amp. What it is is that Ibanez didn't put any paint inside the cavity where the pickguard is, so it makes some noise because of that. Just means your palm muting has got to be spot on
For yours though, maybe there's a bad solder somewhere. I'd have it looked at by a good luthier and get her up to speed.
MatiasTolkki is offline
post #3 of 3 (permalink) Old 12-27-2017, 11:47 PM
Any news on the 550? If you live in ohio I could help you out.
big.mikey08 is offline
Jem fixer upperer ice_monsta Ibanez JEM, UV, JS & Other Signature Models 10 12-29-2014 04:02 PM
Jem7V tone problems near upper frets. amahran Pickups & wiring 24 05-12-2013 02:48 PM
ESP/LTD F-200 Fixer Upper $130 shipped ibanezcollector Classified Ads: Guitars and Gear 0 04-15-2012 09:13 PM
Win Fixer? kirk Off-topic / Miscellaneous 4 10-26-2005 09:13 AM
upper frets buzzing ThomasBJ Tech: Setup, Repairs and Mods 15 05-05-2004 09:21 AM
