Action too low. Not sure of solution. - Jemsite
post #1 of 4 (permalink) Old 06-01-2010, 05:52 PM Thread Starter
I have a RG1570 setup for 9's with low action. The action however is too low. Would changing the setup to 10's in any way help this? I was thinking more tension would be less vibration and less buzzing. Or am I simply going to want the action raised on my 9's?
And yes, the setup I had done is very good, the truss rod and neck are adjusted well enough.
ASLinteris is offline
post #2 of 4 (permalink) Old 06-01-2010, 06:08 PM
Reviews: 98
Re: Action too low. Not sure of solution.
Is the problem your action preference, or buzzing? If you just don't like the action that low, then you'll need to raise is.
AlaskaBat is offline
post #3 of 4 (permalink) Old 06-01-2010, 09:06 PM Thread Starter
Yeah, problem is buzzing. I enjoy action as low as possible.
post #4 of 4 (permalink) Old 06-02-2010, 10:39 AM
Facts, man, facts. Where is the buzzing? What strings, what frets? How much relief does the neck have and what is the string height at the 1st, 12th & 24th frets? No matter how "very good" the setup is, numbers don't lie and that info will help diagnose whether it's the nut height, neck relief, bridge height or frets that is/are the problem.
lwchafin is offline
Problem and a solution! StrunkInPanic All Other Guitars (including Prestige) 7 12-09-2008 11:44 AM
MIDI solution for me, please help 1wi11 Gear, Equipment, Recording & Off Topic 11 10-12-2006 05:17 PM
give me a solution plz kral Tech: Setup, Repairs and Mods 1 07-13-2004 04:59 PM
the final solution? - need help masterplan Gear, Equipment, Recording & Off Topic 2 03-09-2002 06:25 PM
