Alternate for Edge Pro Arm nylon bushings - Jemsite
post #1 of 6 (permalink) Old 09-11-2010, 02:00 PM Thread Starter
Hello, a couple of nylon washers/bushings came for my Edge Pro trem arm. Since these things wear out after use, I was thinking if there is any alternate way to tighten the arm when all my bushings are out of order. This things are are not available in nearest store and I cannot also order online. Thanks.
metalter is offline
post #2 of 6 (permalink) Old 09-11-2010, 02:37 PM
Smile Re: Alternate for Edge Pro Arm nylon bushings
You can order them from Rich (see ibanezrules).
Orochimaru is offline
post #3 of 6 (permalink) Old 09-11-2010, 11:40 PM
Is it possible to install a regular Edge tremolo arm in an Edge Zero?
Melek Taus is offline
post #4 of 6 (permalink) Old 09-12-2010, 11:39 AM
You can also install and original Floyd Rose arm on there without any issues. I always had a general dislike for the stock IBZ arm. I changed over to an OFR arm on my 1527 and it works great!
PBGas is offline
post #5 of 6 (permalink) Old 09-12-2010, 04:27 PM
Remove the white bushings and put clear fingernail polish where they go. Let it dry, then replace the bushings.
Ke^in is offline
post #6 of 6 (permalink) Old 09-13-2010, 08:21 PM
Another option is plumbers thread tape - wind a bit on the arm and push the bushings over. It might take a couple of goes to get the tension right and get the tape sitting properly but should last a good while (I last did one a few months back and it's still tight).
Bildi is offline
Similar Searches
Edge Pro Tremolo Arm Bushings watevar Tech: Setup, Repairs and Mods 5 10-16-2010 02:04 PM
Edge Pro Bushings scotteggshell All Other Guitars (including Prestige) 0 08-27-2009 04:43 PM
Edge Trem arm bushings TKO Ken Tech: Setup, Repairs and Mods 4 12-17-2008 06:57 PM
Bushings on Edge bar wearing out too fast. MicJustMic Tech: Setup, Repairs and Mods 30 09-05-2004 12:29 AM
Lo-Pro Edge Trem Arm Bushings? spiewak Tech: Setup, Repairs and Mods 10 01-08-2003 10:48 PM
