Another veneer project - Jackson Kelly - Jemsite
post #1 of 15 (permalink) Old 10-27-2006, 02:26 PM Thread Starter
Three different veneers on this one. Will either be cranberry with a black burst on the edges or a vintage sunburst.
mfergel is offline
post #2 of 15 (permalink) Old 10-27-2006, 02:41 PM
Re: Another veneer project - Jackson Kelly
Where do you get the veneer? Is it the pressure sensitive kind? Normal glued and do you use a vacuum press?
dragsternj is offline
post #3 of 15 (permalink) Old 10-27-2006, 02:47 PM Thread Starter
I get the veneer off evilbay. It is applied using a heat activated glue. The glue is similar to contact cement but becomes active when heat is applied. I lay the veneer on the surface of the guitar, cover it with a cloth and iron it on. No need for a vacuum press as I flatten the veneer prior to being glued and the iron/glue form an incredibly tight bond.
mfergel is offline
post #4 of 15 (permalink) Old 10-27-2006, 02:47 PM
Nice! plan on doing something similar. it's not too hard is it?
C.Thep is offline
post #5 of 15 (permalink) Old 10-27-2006, 03:10 PM Thread Starter
Check the tech section. I posted a partial how-to on applying a laminate.
mfergel is offline
post #6 of 15 (permalink) Old 10-27-2006, 04:08 PM
what glue are you using?
velocity is offline
post #7 of 15 (permalink) Old 10-27-2006, 05:29 PM Thread Starter
http://www.jemsite.com/forums/showth...ghlight=veneer
mfergel is offline
post #8 of 15 (permalink) Old 10-27-2006, 05:56 PM
thanks
velocity is offline
post #9 of 15 (permalink) Old 10-27-2006, 06:28 PM
BetterBond Heat Lock
post #10 of 15 (permalink) Old 10-27-2006, 09:25 PM
Awesome, congrats
btw, do a sunburst, a pretty subtle one, at that... it already looks beautiful as it is, why cover much up??
marianozz is offline
post #11 of 15 (permalink) Old 10-28-2006, 10:13 AM
Nice!
Regards
André
fettouhi is offline
post #12 of 15 (permalink) Old 10-28-2006, 11:09 AM
mfergel, it looks like you are really having a good time with the laminates and Heat Lock. Very nice work. How is the combination of the two, when working on, say, the contoured portion of a stat top? I've have to imagine that the laminate will want to keep popping up, in that section, until you hit it with the iron. Once you DO hit it, in that area, do you have to maintain pressure on the laminate, until it cools? I'd love to do a few projects like this, and am just feeling out the job. And thanks, by the way, for not only showing us your cool projects, but introducing some of us to that glue. Looks like it really helps make easy work of things.
Racerx2k is offline
post #13 of 15 (permalink) Old 10-28-2006, 04:15 PM Thread Starter
Well, the problem you'd have with this process on a strat type body (curved edge) is that you'd have to sand the veneer to maintain the rounded edge. That means you'd be exposing glue, etc. For this type of process, you really need to have a guitar with a right angled edge, like an RG, Telecaster, Flying V, etc.
Like contact cement, the minute heat is applied, the bond is instant. You don't need to keep it held down for more than a second.
This glue is really one of the best choices....here's why. Contact cement doesn't really allow you to move/position it. If you even partially touch the two pieces, it's stuck. With white/wood glues, it causes the veneer to get moist/wet/ That causes warping unless you have 100% pressure on all areas until the glue is fully dry. Too much room for error in my opinion.
It is a bit of fun. With this Kelly, I'm really looking forward to seeing how it comes out with the stain/paint.
mfergel is offline
post #14 of 15 (permalink) Old 10-28-2006, 08:01 PM
satchboogeyman's Avatar
Good Job man very inspiring. Thanks for the how to's
satchboogeyman is offline
post #15 of 15 (permalink) Old 10-29-2006, 11:53 AM
Not too much of a prob, as I could do a bit of a fade from the solid color on the sides, into the veneered top. I want to do a black flamed top, single hum guitar, with solid black sides and rear. I've seen other flametops have the same fade on the edges, to smooth the transitions, as well, unless I'm missing something, with your method.
Racerx2k is offline
WTB: Jackson Kelly or Jackson King V (USA, white) etuor Classified Ads: Guitars and Gear 1 04-07-2007 04:41 AM
Doing a project, veneer tops jemuniverse777 Tech: Setup, Repairs and Mods 2 07-16-2006 11:39 PM
fs or ft: ibanez rg 550 with emg active electronics for jackson kelly IanRG7421XL Classified Ads: Guitars and Gear 0 06-21-2006 01:04 PM
FS/FT: Jackson Kelly trans blue kbh Classified Ads: Guitars and Gear 6 03-03-2005 05:34 AM
Jackson Kelly Js30 Modded JimmyW Classified Ads: Guitars and Gear 2 03-01-2005 05:43 PM
