Best place to buy Ibanez bridges? Need 540S replacement... - Jemsite
post #1 of 11 (permalink) Old 04-18-2005, 06:00 PM Thread Starter
I have an Ibanez S540 and want to replace its bridge. I am not sure what the
model of the bridge is. It just says Licensed Under Floyd Rose Patents. I
want to replace it, but have no idea what to get. The S540 of course has a
thin body and so I have to make sure that what I get fits. One of the
reasons I want to replace it is because it is all corroded. But mainly, I
don't like how the block is not solid. It is rubber or something. I want a
steel block!
Can someone please tell me what bridges would fit, and where to buy one!
thanks,
brian
bhuether is offline
post #2 of 11 (permalink) Old 04-18-2005, 06:50 PM
Re: Best place to buy Ibanez bridges? Need 540S replacement...
There's no such thing as a rubber block.
I have about 20 EDGE and Lo Pro's in stock in many colors.
Rich is offline
post #3 of 11 (permalink) Old 05-06-2005, 08:49 AM
Rich, how does one get ahold of you to buy one? Also, do you have other parts for RG's for instance? I'm thinking my black RG 550 would look good with a Gold Edge instead of the black one I have, and with a gold nut, etc.. For now, I'd love to get just a new scratch plate / pick guard..
Thanks
Tim
DotNetTim is offline
post #4 of 11 (permalink) Old 05-06-2005, 09:42 AM
Rich has all the hardware you would want (factory tuners, nuts, and bridges) but for pickguards check out Pickguard Paradise or EKG (both have banners at the top). To get a price and mailing information you have to email rich with the quantity and item numbers.
Kontalonis is offline
post #5 of 11 (permalink) Old 05-06-2005, 01:15 PM
Originally Posted by Kontalonis
but for pickguards check out Pickguard Paradise or EKG .
Some people actually prefer factory parts
Nobody in the US is actually using metric material, it's all the same SAE stuff everybody else is using. If you want what you have on it you have to buy factory [or, from somebody overseas cutting aftermarket guards that's using metric stock]
Edge is no available in black, but the Lo Pro is and is a direct swap.
Rich is offline
post #6 of 11 (permalink) Old 05-06-2005, 05:00 PM
sorry rich i didn't know you had the factory guards. I guess for everything you need Rich is the man these days.
post #7 of 11 (permalink) Old 05-06-2005, 06:55 PM Thread Starter
But how do I know if the LoPro will fit properly in my S540?
-brian
bhuether is offline
post #8 of 11 (permalink) Old 05-06-2005, 07:10 PM
As Rich just said, it will work. It "is a direct swap".
ryanb is offline
post #9 of 11 (permalink) Old 05-06-2005, 07:14 PM
Not everything, I still don't stock anything TRS
[OK, I *just* finally ordered some TRS bars]
Rich is offline
post #10 of 11 (permalink) Old 05-06-2005, 07:49 PM
dex
When you say that the block is not steel, do you mean the trem plate - if you want one that has all steel trem plate I'm afraid you'll have to go for OFR but it'll look wrong in the rout (sp?).
Gotoh Edge/Lo pro bridges are one of the best in the business so make sure you read up about them before you swap it for something inferior.
ilia
dex is offline
post #11 of 11 (permalink) Old 05-06-2005, 11:21 PM
ZR?
excelent bridge, (IF IT WERENT FOR THAT WOBBLE, i sent an email to the shop i bought my sabre from to see if they could do an arm swap, no reply.)
superhairycamel is offline
floyd rose , pickguard paradise , scratch plate , trem plate
Ibanez Bridges Ericson Gear, Equipment, Recording & Off Topic 3 12-27-2012 04:50 PM
Replacement neck options for 1990/1 540s wildstar Tech: Setup, Repairs and Mods 7 12-11-2009 10:50 PM
Best place for replacement pickguard? waylay00 All Other Guitars (including Prestige) 1 01-15-2008 08:13 PM
Ibanez Bridges Jacobpm64 All Other Guitars (including Prestige) 8 10-27-2004 03:40 PM
Im baffled by ibanez bridges themaidenmaniac All Other Guitars (including Prestige) 9 06-27-2004 07:16 PM
