Best way to diagnose a bad selector switch? - Jemsite
post #1 of 6 (permalink) Old 01-16-2014, 09:58 PM Thread Starter
My '92 RG550 has an intermittent short in the rhythm pos. I am thinking of pulling the springs off the back, lifting the FR off the posts, and pulling the pickguard to inspect the switch. This would allow me to drop the pg back in and put the FR back onto the posts. Then plug the guitar into the amp to test.
Is there an easier way? ty
jer3d is offline
post #2 of 6 (permalink) Old 01-17-2014, 09:06 AM
Re: Best way to diagnose a bad selector switch?
There's a much easier way (as I have experience with bad selectors):
Put it in the position that keeps going out. Use one of your allen wrenches to tap on the coils of the pup. If there is sound the pup works okay.
After that, change the position on the selector. Slide it into neck pos then put it back into Bridge pos. If it goes in and out constantly, it's a selector problem.
MatiasTolkki is offline
post #3 of 6 (permalink) Old 01-19-2014, 11:08 PM Thread Starter
Here is the RG...
...and after pulling the pg...
...here is the switch disassembled. I bent the outside feet of the two copper pieces on either end of the switch up a bit hoping they would make better contact with the switch plate.
After getting it back together I tried it out and so far the switch works much better. Keeping my fingers crossed for awhile though.
jer3d is offline
post #4 of 6 (permalink) Old 01-20-2014, 11:16 AM
If you have it open again, spray a little contact cleaner or wd40 onto the contacts.
just4kinks is offline
post #5 of 6 (permalink) Old 01-20-2014, 11:43 AM
Reviews: 64
Call NASA.
6fingers is offline
post #6 of 6 (permalink) Old 01-20-2014, 12:31 PM
Originally Posted by 6fingers View Post
Call NASA.
GUITARMAGEDDON is offline
rg550! rg550!
5 way selector switch kenmx10 Pickups & wiring 2 04-12-2012 11:05 PM
Pickup selector switch moonlight Tech: Setup, Repairs and Mods 3 12-03-2011 05:03 AM
Selector switch, pots... Devon8822 Pickups & wiring 3 01-08-2010 03:53 AM
P-Up Selector Switch Guitarmiester Pickups & wiring 0 10-05-2006 12:27 PM
COR-TEK 3-way selector switch Contra Pickups & wiring 1 04-14-2003 11:08 PM
