brand new RG1570, quality problems - Jemsite
post #1 of 16 (permalink) Old 01-09-2010, 01:54 PM Thread Starter
Hi guys,
First real post on this forum but I've reading/lurking for about a year or so, when I started thinking about buying a new Ibanez. I've been stolen my first Ibanez, a 3120, a few years ago, and since then I've always felt the need for another Ibanez! So I finally took the plunge and ordered a 1570, a somehow different animal (pickup config, woods...) but a MIJ Prestige with the fast neck, high-quality bridge and all.
So I got the guitar yesterday. 2008 production... but boy, what happened at the factory? First, the bridge knive on the low-E side was sitting against the top straight part of the post, about 1/16" from the edge of the post and on the verge of popping out! In fear of it actually popping out, I had to push the bridge back down in place. The Cosmo finish is scrapped off the post on about 3/16" (not good for oxydation/rust), and I fear the knive edge might be damaged. As well, some of the plating chipped off and got stuck in the V groove on the high-E-side post due to the knive tilting because of the bridge being jacked up on the other side.
Also there are about 10-15 small white/light gray spots that seem to be missing paint, on the top edge in the jack area and around the back plate.
And lastly, there is about a dozen small straight white marks on the fretboard, spread on an area spanning 3 frets (missing stain?).
What I find odd, is that close inspection shows absolutely no sign of the guitar being ever played. No pick marks, not even a single fingerprint except from me handling it.
I never returned a guitar before, let alone to a mail-order/online store; do you guys think this falls under warranty and qualify for an RMA? I think it does, but I don't want to send back the guitar only to find out the store charges back the return shipping cost and re-stocking on me because they conclude to a regular non-warranty return.
Last question. I really like the 1570, the specs, neck, color and all, and I plan to exchange it for the exact same model; but I wonder: are these problems common nowadays? I'm kinda perplexed. My 3020 (circa 1999) sure didn't exhibit that sort of problems.
Thanks a bunch in advance.
markiv2290 is offline
post #2 of 16 (permalink) Old 01-09-2010, 02:23 PM
Reviews: 15
Re: brand new RG1570, quality problems
Can't comment on the paint issues without seeing some pics but the bridge being out of its groove has happened in transit, not in the factory. Someone put strings on it and tuned it, remember.
MarkE is offline
post #3 of 16 (permalink) Old 01-09-2010, 02:49 PM
Reviews: 7
Where did you order the guitar from?
Timbaline is offline
post #4 of 16 (permalink) Old 01-09-2010, 03:41 PM Thread Starter
I bought it from FM.
I'm definitely not a pro setup technician but, honestly, I just can't figure how the knive could have "jumped" out of its place. I mean, with the string tension pulling the knive towards the post, how could the bridge back off 1/8" to clear the kive out of the V groove?
Also, now that the bridge is back in place, from the bottom of the guitar looking towards the neck I see the bridge is not parallel to the body from the low-E side to the high-E side. By that I mean the low-E side knife insert rib (which I look at from the side of the trem) is at the right height, but the high-E side sinks about 1/8 lower inside the trem cavity. These are screw posts, so either something went wrong with the setup or the high-E side post screwed itself down a few more turns
post #5 of 16 (permalink) Old 01-09-2010, 04:33 PM
From the pic, those don't look like much to me but it's your guitar.
They typically don't "stain" rosewood fingerboards. More than likely that just some residual polishing/buffing compound or something like that. I'd bet if you oiled the fingerboard (which one should do with any new guitar that has a rosewood or ebony fretboard) those white marks will disappear.
The knife edge thing probably happened in transit.
The question you really need answered is was the guitar inspected prior to be packed for shipping? Personally, I only order from on-line vendors that specifically offer this service and advertise it on their site.
IMHO, based upon selling instruments for a living for 12 yrs., none of these issues would fall under warranty because there are no defects in materials or workmanship that I can see from the pics you posted. Even if something does fall under warranty, shipping costs are not covered under warranty so you'll be paying for that.
If you are really that displeased with the instrument then you should contact the dealer you purchased it from to come to some kind of resolution.
toneboy is offline
post #6 of 16 (permalink) Old 01-10-2010, 12:36 AM Thread Starter
The marks on the body were hard to get on camera, but they are clearly visible in person, they are white so its quite a contrast on the very dark paint.
That's what I thought initially, and I tried to rub them off but alas, the marks just wouldn't come off. Didn't spend much time on these though.
I don't know whether if they inspect instruments or not... As far as the bridge is concerned, if its in transit then the package must have been banged around real bad... surprisingly the box doesn't look like it suffered all that much.
post #7 of 16 (permalink) Old 01-10-2010, 01:19 AM
If putting ore oil on the neck doesn't get them then I would just take a soft tooth brush to it. Rosewood is not the smoothest wood. It pores and things can get into them.
You'd be surprised at how packages are man handled during shipping. They're not exactly handled like eggs.
Plain and simple, you need to contact the dealer to resolve this. A thread here isn't going to do that.
toneboy is offline
post #8 of 16 (permalink) Old 01-10-2010, 09:47 AM Thread Starter
I did contact the dealer since my last post. It's going back to be exchanged. Hope the "Brown" doesn't mess up the second one...
post #9 of 16 (permalink) Old 01-10-2010, 10:15 AM
Excellent, that's good news. I've done a lot of shipping with guitars over the years and have yet and only had one minor incident so the odds are in your favor.
BTW, when you received the guitar, was it detuned (were the strings slack)? I know the bridge had shifted (which would make the strings looser than normal) but were they really loose? That's one thing some folks don't do - loosen the strings up before shipping - which is important. It takes stress of the neck so if the guitar does get banged around, at least it won't have the tension of the strings pulling on it too.
toneboy is offline
post #10 of 16 (permalink) Old 01-10-2010, 03:42 PM
The reason to detune a guitar came from the older Gibson's that would snap a headstock off from shipping shock. Take the string tension off to avoid the extra pressure.
Never detune a floating bridge. You're going to make it easier for the trem to blow off the studs with shipping shock because you're reducing the amount of pressuse against it. These guitars have no issues with snapping headstocks, so all you're doing is making the buyer have to setup the guitar to where it should have been when he opened the case.
Rich is offline
post #11 of 16 (permalink) Old 01-11-2010, 02:10 PM Thread Starter
Upon arrival the guitar was clearly out of tune, however I can't recall exactly to what extent it was detuned before I popped the bridge back in place. But, with the knife back in its groove, the detuning was far from being even accross all 6 strings, the low-E being the most out-of wack. But strings weren't "slack" by any means.
And thanks Rich for the small bit of guitar history!
post #12 of 16 (permalink) Old 01-11-2010, 03:30 PM
You've got the same guitar as me and mine is perfect, no issues whatsoever, I've changed the humbuckers to an AN - TZ and they're pretty awesome TBH, hope you enjoy the 1570 as much as I do, It's a top piece of kit.
rg1570 col is offline
post #13 of 16 (permalink) Old 01-22-2010, 01:22 PM Thread Starter
Update: I got the replacement 1570, and I must say, this one looks flawless
Looks like more attention was put in the setup on that one, even the pickups height is about right. Can't wait to try it out tonight after the mandatory restring/retune!
post #14 of 16 (permalink) Old 01-22-2010, 10:39 PM
Beat me to it, Gibson and their hot swappable headstocks were the reason for that mother's tail of guitar shipping.
De-tuning a trem guitar you are asking for that bridge to come off and slidig around your paint job.
Digital Jams is offline
post #15 of 16 (permalink) Old 02-01-2010, 09:22 PM
i have an rgr 1570 that i ordered through my local dealer. i had a couple issues with it that the dealer readily addressed. its performed flawlessly for the past year. the issues you had are just more proof to me that buying before trying is not a good practice
mcavoyfam6 is offline
prestige , quality , rg1570
Lefty RG1570 some problems.. nullsys All Other Guitars (including Prestige) 3 01-20-2008 01:16 PM
rg1570 tuning problems Force2BRW All Other Guitars (including Prestige) 7 12-17-2007 02:58 AM
Intonation Problems With RG1570. PLEASE HELP! shogun Tech: Setup, Repairs and Mods 20 03-29-2007 08:35 AM
Brand new RG1570 evo/paf FS Shibito Classified Ads: Guitars and Gear 3 01-07-2007 03:42 PM
