Bridge Maintenance - Jemsite
post #1 of 2 (permalink) Old 03-27-2010, 04:45 PM Thread Starter
Bridge Maintenance
I have been making some adjustments to my RG350 and the fine turners are starting to stick. What would you recommend for keeping them smooth? Can I use regular WD-40 or is there a special product I should get?
Thanks.
Mario83 is offline
post #2 of 2 (permalink) Old 04-08-2010, 09:28 PM
Re: Bridge Maintenance
Personally I wouldn't use that, as I'd be concerned about any effect it might have on the guitars finish. Also being a spray it could get anywhere, and I wouldn't want it seeping into wood, or under any lacquer.
You don't say what adjustments you've made, or the age of the guitar/tuners. If its just since you've changed things; have you done something to change the string's pull or its position, that might interfere with smooth turning. If your tuners are new they may have worn, and there could be some muck in there. If they're older they might have picked up gunk over the years, in either case you may want to take them apart for a clean. Whilst apart, and away from the guitar, I would get the WD40 out, as its a good cleaner (just make sure you've wiped them well before putting them back on your guitar).
If you just want a lubricant, personally I'd use a light oil, a light sowing machine oil if you can get it, but nothing no heaver than 3-in-1.
rocknrollmouse is offline
floyd rose bridge , trs bridge
Unfinished neck maintenance Nesi Tech: Setup, Repairs and Mods 5 03-25-2007 01:33 AM
STRING AND FRETBOARD MAINTENANCE Batchimp RG Tech: Setup, Repairs and Mods 24 01-10-2007 10:11 AM
Lo-Pro Maintenance FruitSnax Tech: Setup, Repairs and Mods 4 06-10-2003 05:29 PM
Pickguard maintenance - ... what's your solution dacmo Tech: Setup, Repairs and Mods 10 04-21-2001 10:02 AM
In Need of advice - Neck Maintenance RG550 Gear, Equipment, Recording & Off Topic 3 02-14-2001 10:41 PM
