Bridge problem with my ESP - Jemsite
post #1 of 9 (permalink) Old 02-20-2007, 01:42 PM Thread Starter
Reviews: 5
I bought a new ESP LTD M200
It has an esp licensed bridge
I decided to change the strings and guess what
the allen to release the string on the bridge is at an angle that I cant get the allen key into it
the fine tuners are in the way and you cant unscrew them fully
I am left bamboozled, is this a manufacturing problem?
regards
wildchild
wildchild247 is offline
post #2 of 9 (permalink) Old 02-25-2007, 05:51 PM
Re: Bridge problem with my ESP
no, lift the bridge up using the whammy bar, a bit of initiative is all it takes.
And are you a Bodom fan?
guitar_legend is offline
post #3 of 9 (permalink) Old 02-25-2007, 06:23 PM
Use the whammy bar to tilt the bridge, then unlock the string bolt.
buddroyce is offline
post #4 of 9 (permalink) Old 03-05-2007, 03:01 PM Thread Starter
Reviews: 5
Yes I am a huge bodom fan
The bridge is more like a edge lo trs
and the fine tuners are in the way of the allen key bolt
I think it may be a manufacturing fault
post #5 of 9 (permalink) Old 03-05-2007, 03:09 PM
replace it with an ofr(idk if it fits) if its a problem with the actual bridge, + it would be an upgrade from a licensed
newbieguitarmaker is offline
post #6 of 9 (permalink) Old 03-07-2007, 03:00 PM
Offtopic. I was at lake Bodom today...
Cheers
Luca
Luca is offline
post #7 of 9 (permalink) Old 03-07-2007, 03:20 PM
See if you can obtain shorter allen key from somewhere.
What you're describing is a pretty common "problem" on low profile floyds, including the lo pro edge.
If you can't find a shorter one, just saw off 5mm of the allen key tip with a metal saw and you'll be fine. That's what I always do.
horstausmforst is offline
post #8 of 9 (permalink) Old 03-07-2007, 03:52 PM
I met Alexi
post #9 of 9 (permalink) Old 03-14-2007, 08:14 AM Thread Starter
Reviews: 5
Originally Posted by guitar_legend View Post
I met Alexi
Nice one
what was he like?
Also I am getting a replacement cos those bridges are not supposed to be like that
the problem with getting a smaller allen key is that the gap between the bolt and fine tuners are half a centimetre
so thats quite an impossibility
wildchild
pro edge
Problem w/ bridge pickup on my JEM90HAM: as singlecoiled ! nmanel Pickups & wiring 8 03-18-2007 12:33 AM
Rg-7620 Problem Sephiroth000 All Other Guitars (including Prestige) 4 11-26-2003 07:19 PM
Putting the new Ibanez ZR Bridge into a 2002 Ibanez rgt42??? ShredBird All Other Guitars (including Prestige) 6 06-16-2003 03:09 AM
Strats Tremelos, help? Ignorance Tech: Setup, Repairs and Mods 9 11-10-2002 03:39 PM
Is this going to be easy??? - Bridge replacement for RG421 ChrisReedSmith Tech: Setup, Repairs and Mods 0 04-18-2002 08:25 AM
