Bridge Replacement for '89 EX350 - Jemsite
post #1 of 3 (permalink) Old 05-17-2015, 04:21 PM Thread Starter
Is there a direct replacement for the licensed Floyd that came in the 89 EX350s? I found one for cheap the other day, but it needs a new bridge.
Thanks!
bfarr is offline
post #2 of 3 (permalink) Old 05-17-2015, 10:21 PM
RGTFanatic's Avatar
Re: Bridge Replacement for '89 EX350
The EX guitars came with a TRS101 which was a pretty good floyd copy. It DID have hardened knife edges which should still be in decent shape if they haven't been abused. Why do you feel it needs to be replaced?
To accurately answer your question, an OFR should drop in without any modifications to the guitar
RGTFanatic is offline
post #3 of 3 (permalink) Old 05-18-2015, 12:41 PM
Reviews: 5
I don't know if an OFR will fit or not. The TRS-101 had wings rather than 90-degree square corners on the OFR. And the TRS studs are spaced 74mm apart; OFR is 73.91. So it might not fit well on the studs or in the cavity. Best bet is probably to seek out a new TRS-101 (Jackson put them on guitars too--they called it the JT580LP).
jem7vwh is offline
1989 , ex350
Ibanez EX350 xxxscotxxx All Other Guitars (including Prestige) 4 12-12-2008 09:46 PM
EX350 Devon8822 All Other Guitars (including Prestige) 3 11-05-2008 02:40 PM
bridge replacement? arnab Tech: Setup, Repairs and Mods 6 07-03-2007 02:14 AM
EX350 EdE All Other Guitars (including Prestige) 2 05-15-2004 03:30 AM
