Building a rg from mismatched necks/bodies - Jemsite
post #1 of 6 (permalink) Old 04-25-2013, 11:28 PM Thread Starter
I have been wanting to buy a rg body from the bay, I see570,470,350,320's all over the place, so my question is if I were to buy one of those would I be able to mismatch another rg neck for this guitar build project, for example if i buy this 570 body could a rg350 neck be put in without any hassle or was there any differences in size from different years of production. All the bodies Im looking at would have the round heel and not the square one.
nathan80 is offline
post #2 of 6 (permalink) Old 04-26-2013, 12:17 AM
Reviews: 13
Re: Building a rg from mismatched necks/bodies
Hi Nathan.
What is your budget? You can fit them all but some will require more modification than others.
I would not recommend putting a 350 neck with a 570 body and vice versa. Doing so will require you to fill the existing holes in the neck and redrill. If however you have the time and the skills you should be fine.
However if you want to keep it really simple, stick to:
MIJ bodies / parts with MIJ; and
MIK parts / bodies with MIK parts etc
You should then be pretty ok. The only exception to this is with Japanese Prestige necks - from what I recall they are a little wider and if not matched with a prestige body, the neck pocket will need to be widened.
I don't known about the Indo prestige necks.
You will need to consider the type of trem you would like to use too otherwise you may have to route the body.
In my opinion if you are going to do this it is only really worth it on a Japanese neck and body.
Happy to go in to more detail if you need me to. I have done this a few times....
-Wolfram
Wolfram is offline
post #3 of 6 (permalink) Old 04-26-2013, 12:43 AM
RGTFanatic's Avatar
Originally Posted by Wolfram View Post
Hi Nathan.
-Wolfram
Great reply Wolf!!
Nathan: You need to spend a good deal of time deciding exactly what you want the guitar to be in the end. Once you do that, a little homework will put you in good shape.
One note: Prestige necks weren't widened at the heel until 2005, so there are some out there that are 56mm......... be careful to ask the seller exact questions about the neck pocket/heel or, as Wolf said, you'll be doing some modifications.
RGTFanatic is offline
post #4 of 6 (permalink) Old 04-26-2013, 08:35 AM
Honestly, I wouldn't build an entire guitar from parts. It will end up costing you way more than building an entire guitar.
I would instead start with a complete guitar and then if you want to make changes, buy the corresponding part (like a different neck) and then sell the one you already have. This will be the most budget friendly way to do this. Buying all the hardware, electronics, etc really adds up when you're buying it as parts.
You can generally find a nice RG570 with the all access neck joint in the $300-400 range. Guitar Center has a few listed in their used section. They actually have a very cool and somewhat rare RGR570 for $400 in Spokane, WA. The extra R is for reverse headstock. They have it mislabeled as an RG550.
Takin' a Ride is offline
post #5 of 6 (permalink) Old 04-26-2013, 01:10 PM
good point,, you might end up spending 200 or more just for a neck on the bay
GUITARMAGEDDON is offline
post #6 of 6 (permalink) Old 04-26-2013, 01:18 PM
Reviews: 11
I can show you several MIJ RG's for under 300, most with hard shell cases too.
linuxpenguin is offline
necks & bodies andyt Tech: Setup, Repairs and Mods 37 09-06-2012 09:14 PM
If anyone is looking for cheap bodies and necks... nsv9292 All Other Guitars (including Prestige) 0 08-09-2012 07:39 PM
WTB: Broken bodies and necks Thund3rDong Classified Ads: Guitars and Gear 3 06-14-2010 12:38 PM
js bodies, necks etc... firks Ibanez JEM, UV, JS & Other Signature Models 5 02-11-2009 11:26 AM
Necks and Bodies - Necks and Bodies sebastian Ibanez JEM, UV, JS & Other Signature Models 20 03-29-2001 09:50 AM
