can an EDGE PRO II be swapped out to an EDGE PRO? - Jemsite
post #1 of 5 (permalink) Old 11-05-2004, 11:30 AM Thread Starter
Can the korean edge pro II be swapped out to an EDGE PRO without any modification on models like the RGT42?
A mate of mine wants to get it done, but it would be me doing the job for him as he's too cheap to go to a tech, any thoughts?
cheers,
Spike.
Societysucks is offline
post #2 of 5 (permalink) Old 11-06-2004, 05:54 PM
The Edge Pro appears to have a longer base plate - I'm pretty sure that it wouldn't fit into the same route; the routing would have to be elongated to allow for that.
I don't have measurements, I'm just going by pictures and having seen some of them in person.
I suspect that size difference is quite deliberate, too...
steve is offline
post #3 of 5 (permalink) Old 11-06-2004, 07:42 PM
The scuttlebut from the company is the EP is set further back from the nut to compensate for the saddle inserts and for this reason it can't be swapped with anything.
Rich is online
post #4 of 5 (permalink) Old 11-07-2004, 04:41 AM
Cunning or Stupidity ? We will never know (on topic)
I've said it before, Anything WILL fit anything with routing and re-mounting/Re-siting the posts ... It maybe a tad overkill, but if it's what you want i'd suggest giving EKG or LGM a call
HTH
Rob
Jem7RB MK is offline
post #5 of 5 (permalink) Old 11-08-2004, 04:47 PM Thread Starter
Like I said my mate is to cheap to go to a tech, I've advised him to simply leave it alone.
I did a few EMG pickups on his LTD a few years ago and since then I've been his goto guy for guitar related problems.
base plate
WTT: Edge/Lo-Pro Edge Whammy bar for Edge III (black) GuitarAl96 Classified Ads: Guitars and Gear 0 07-25-2013 10:30 AM
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
Can the pivot studs of the edge pro be swapped out JuanCaca All Other Guitars (including Prestige) 4 11-08-2004 04:02 PM
