Case question for 540S7? - Jemsite
post #1 of 4 (permalink) Old 11-22-2006, 11:56 PM Thread Starter
Anyone know for sure what Ibanez case will fit a 540S7? Im assuming whatever case fits S models normally will work but I was concerned that the headstock might be too long.
Any help appreciated
Lee
eelblack2 is offline
post #2 of 4 (permalink) Old 11-23-2006, 02:24 AM
Re: Case question for 540S7?
The M100C case fits a 7 string headstock fine.
nyck is offline
post #3 of 4 (permalink) Old 11-28-2006, 08:47 PM
the 540S7 originally came with the ibanez UV1000C case [the wooden one covered with tolex], and will fit easily inside. i also have an ibanez M100C case [the molded plastic one]. the headstock on my 540S7 will just barely fit inside that case if i slide the headstock in first, then lower the body of the guitar.
post #4 of 4 (permalink) Old 11-30-2006, 04:21 AM
+1
Regards
André
fettouhi is offline
What is the real original Jem case? bluealien Ibanez JEM, UV, JS & Other Signature Models 11 11-29-2005 11:38 PM
RG/Jem/Universe case question Cryptic Ibanez JEM, UV, JS & Other Signature Models 4 06-30-2004 09:14 AM
RG 2027 Question : Dimensions & Weight with case 1 1 Dragon 2 2 2 All Other Guitars (including Prestige) 2 12-08-2002 08:20 PM
question on uv1000 case stratman219 Ibanez JEM, UV, JS & Other Signature Models 9 11-02-2002 08:12 AM
JEM 10th Case Mystery Solved! - Would you believe?? Rich Ibanez JEM, UV, JS & Other Signature Models 55 12-28-2001 02:54 PM
