Change tremolo system / rg 370dxleft - Jemsite
post #1 of 14 (permalink) Old 03-11-2011, 10:51 AM Thread Starter
I have rg 370dxl , can i change the edge 3 , with smthing better, such as edge pro, or an original floyd rose??
qwerqwer is offline
post #2 of 14 (permalink) Old 03-11-2011, 11:21 AM
Re: Change tremolo system / rg 370dxleft
I'm sure you can as long as the bridge posts are the same distance apart.
Lesterblester74 is offline
post #3 of 14 (permalink) Old 03-11-2011, 12:33 PM Thread Starter
Do you know if edge pro fits?
qwerqwer is offline
post #4 of 14 (permalink) Old 03-11-2011, 01:11 PM
if your guitar already has that edge 3 in it then the edge pro should fit as long as the posts are the same distance apart which they should be.
post #5 of 14 (permalink) Old 03-11-2011, 03:54 PM
Reviews: 120
Doing a SEARCH on this site will give you some great results!
http://www.jemsite.com/forums/f21/ed...olo-68062.html
LonePhantom is offline
post #6 of 14 (permalink) Old 03-11-2011, 05:08 PM
RGTFanatic's Avatar
apparently that's too much work...... I want INSTANT GRATIFICATION!!!!.........lol
BTW.... why is it that we spend so much time making those detailed, picture laden posts that are loaded with information such as this??? Oh yea!! so that no one will read them..........lmao
RGTFanatic is offline
post #7 of 14 (permalink) Old 03-13-2011, 03:51 PM Thread Starter
Results:
edge pro fits
ofr fits
qwerqwer is offline
post #8 of 14 (permalink) Old 03-13-2011, 06:54 PM
I have an RGT42DXFM that I just purchased used in very good condition. I can confirm that the Original Floyd Rose fits. The side that the trem arm screws into is really close to the routing, the other side has a little bit of a gap. The saddle clamp bolts clear the rear of the routing for pulling up. I can also confirm that Schaller Floyd Rose studs will thread into the stock Edge 3 body inserts.
I was pretty excited to get this guitar. I bought the OFR and Dimarzio Evolution neck and bridge pickups and installed them before really playing it. The Edge 3 I removed had crinkled metal on the knife edges where they met the posts. Really poor quality there. So I get all this stuff installed and I spend several hours yesterday trying to get a setup. My main guitar for many years has been a '91 RG550. It has a great low action with very little fret buzz. The RGT42 requires a much higher action to make it to where the high strings are bendable all the way up the neck without choking them. There is an especially bad spot bending the high E at the 17th 18th fret. I've had the truss rod adjusted through the whole range of recommended neck reliefs, I just can't come anywhere near the action of the 550. My Ovation acoustic has a better action than this guitar. Sadly, it looks like a fret levelling needs to be done. I was sort of wanting a prestige without the full cost, with parts I could remove when (if) I sold it. But it looks like I got a lemon instead.
burpootus is offline
post #9 of 14 (permalink) Old 03-13-2011, 07:05 PM
Reviews: 98
AlaskaBat is offline
post #10 of 14 (permalink) Old 03-13-2011, 09:41 PM
I'm going to go ahead and pull my foot out of my mouth...I put a shim under the saddle for the high E and made things a lot better. From reading it seems that shimming the saddles is a necessity when setting up a new FR, the radius isn't a match for the neck.
post #11 of 14 (permalink) Old 03-13-2011, 10:22 PM
Reviews: 11
just get an edge pro. better trem and the radius might be a bit better as well. but its not cheap
D.M.RG7620 is offline
post #12 of 14 (permalink) Old 03-28-2011, 02:53 PM
Reviews: 9
I have a Lo Pro in my 370DX. You'll either need the Schaller posts or have the standard inserts drilled out to fit the locking inserts. The posts that come with the Lo Pro don't fit the Edge inserts. The Schaller posts will cost you about $10 and screw staright into the existing Edge inserts. Also, you'll find it might not stay in tune too well so use some Planet waves Lubrikit or Nut sauce and that will cure any tuning stablility issues you may come across. You may also have to dremmel out the tiniest amount of wood at the front of where the tremelo sits as the tremelo may foul the body of the guitar. It is only a tiny amout and unless you use a magnifying glass you won't see it.
longi is offline
post #13 of 14 (permalink) Old 03-28-2011, 03:17 PM
Will gotoh trem fot in edge III cavity?
post #14 of 14 (permalink) Old 03-28-2011, 03:36 PM
Reviews: 98
As mentioned above--a simple search wil provide the answer:
tremolo system upgrade
Switching my tremolo system Yelgath Tech: Setup, Repairs and Mods 6 11-21-2008 11:54 PM
tremolo system from rg 770 steini All Other Guitars (including Prestige) 8 09-12-2008 04:47 AM
tremolo system for my RG320? bjamin86 All Other Guitars (including Prestige) 2 05-21-2006 11:59 PM
