Changing a nut, squeeky bridge; questions. - Jemsite
post #1 of 7 (permalink) Old 06-20-2006, 03:57 AM Thread Starter
Hey guys, just 2 questions.
I bought a locking nut off ebay to replace my current one which doesn't work properly, and I was wondering if swapping them is as easy as unscrewing the current one (bottom mounted) and putting on the new one. So, no glue or anything? How tight the new has to be?
My other question is about my bridge, when ever I do a whammy trick, my bridge makes that sound, like a rusty gate or something, I forgot what it's called. So, what do I lubricate and clean? And what do I used? WD-40?
Thanks
Edit: ffs I posted an repair/mod question in the wrong forum again. If a mod could move it I'd appreciate it.
bradc1988 is offline
post #2 of 7 (permalink) Old 06-20-2006, 05:22 AM
Reviews: 120
Re: Changing a nut, squeeky bridge; questions.
You don't need to glue anything for the locking nut. Just unscrew the existing one and put the new one in. Just do it tight enough so that it cannot move. Too tight and you'll crack the neck.
If you put in the new one and your strings buzz around the first 5 or so frets you might need to shim it. If the new nut doesn't come with a shim you can make some out of some card or thick paper. Just make a thin one that sitson the edge closest to the fret board.
LonePhantom is offline
post #3 of 7 (permalink) Old 06-21-2006, 02:48 AM Thread Starter
I don't like the sound of that, I'll only go so it's a snug fit.
Thanks
post #4 of 7 (permalink) Old 06-21-2006, 03:39 AM
JJEMMER777's Avatar
If you put in the new one and your strings buzz around the first 5 or so frets you might need to shim it. .
Pop cans or preferably BEER cans make for great shims
JJEMMER777 is offline
post #5 of 7 (permalink) Old 06-22-2006, 10:45 AM Thread Starter
A shim is a thin peice of something to raise the nut?
post #6 of 7 (permalink) Old 06-22-2006, 12:28 PM
Yep, Rich has them (banner above). They are inexpensive. Get several differant sizes (thickness).
S-man is offline
post #7 of 7 (permalink) Old 06-22-2006, 12:31 PM
BTW...hopefully it does buzz without the shims. You then will use the shims to eliminate the buzz. If it doesn't buzz without shims, you probably need to work on the actual nut to obtain the lowest action possible.
S-man is offline
fret board , locking nut
sr505 direct replacement pickups and bridge id Pickups & wiring 11 07-27-2010 02:52 PM
Changing string gauge questions ZenekZelman Tech: Setup, Repairs and Mods 4 10-24-2005 01:45 AM
Identify my Bridge please Rockstar Tech: Setup, Repairs and Mods 4 06-24-2003 05:55 PM
Putting the new Ibanez ZR Bridge into a 2002 Ibanez rgt42??? ShredBird All Other Guitars (including Prestige) 6 06-16-2003 03:09 AM
Strats Tremelos, help? Ignorance Tech: Setup, Repairs and Mods 9 11-10-2002 03:39 PM
