Cleaning/oiling fretboard - how to with strings ON? - Page 2 - Jemsite
post #16 of 16 (permalink) Old 07-24-2019, 04:56 PM
Re: Cleaning/oiling fretboard - how to with strings ON?
Originally Posted by toneboy View Post
You can't really clean the fingerboard (well) unless you take all the strings off and while you can oil it with the strings on, it's a bit of a pain in the butt and you will (obviously) get oil all over your strings.
You won't hurt the neck in anyway by taking all the strings off for a short period (e.g. not years and year) of time. Will the neck flex a little when you take the strings off? Yes but it will also go re-flex when you put the strings back on.
In regards to tuning, it will be easier to get the guitar back in tune if you block the bridge (underneath the fine tuners) before you take all the strings off.
This is called as slandered answer. Thanks for your guidelines
sofialucas is offline
cleaning/oiling fretboard
Just got a JS6! Need advice on cleaning it up / oiling Toadfish Ibanez JEM, UV, JS & Other Signature Models 12 08-30-2009 08:18 AM
Changing strings/cleaning fretboard on LP Standard jemeister All Other Guitars (including Prestige) 1 06-09-2007 12:26 PM
oiling fretboard JasonMalmsteen Tech: Setup, Repairs and Mods 36 01-29-2007 11:42 PM
Fretboard cleaning NeglectedField All Other Guitars (including Prestige) 10 05-30-2006 10:21 AM
fretboard cleaning Drache713 Tech: Setup, Repairs and Mods 2 09-17-2004 11:20 AM
