Cleaning/oiling fretboard - how to with strings ON? - Jemsite
post #1 of 16 (permalink) Old 09-24-2009, 04:41 PM Thread Starter
I recently bought a new Ibanez (RG2570Z) and unless my memory is failing me, I recall the manual saying to change strings one at a time to help neck/tuning stability.
Does that sounds right? Reasons I aks is that I was about to clean the frets/fretboard and then apply some Fret Doctor. Obviously that would be easier to do if all the strings were off but I do not want to compromise my current action.
Any suggestions or comments on this? thanks
jtmann is offline
post #2 of 16 (permalink) Old 09-24-2009, 05:05 PM
Re: Cleaning/oiling fretboard - how to with strings ON?
You can't really clean the fingerboard (well) unless you take all the strings off and while you can oil it with the strings on, it's a bit of a pain in the butt and you will (obviously) get oil all over your strings.
You won't hurt the neck in anyway by taking all the strings off for a short period (e.g. not years and year) of time. Will the neck flex a little when you take the strings off? Yes but it will also go re-flex when you put the strings back on.
In regards to tuning, it will be easier to get the guitar back in tune if you block the bridge (underneath the fine tuners) before you take all the strings off.
toneboy is offline
post #3 of 16 (permalink) Old 09-24-2009, 08:56 PM
1. Block the trem
2. Loosen all your strings until they are flabby.
3. Stick wood dowel underneath 1st fret.
Presto!
Yousef is offline
post #4 of 16 (permalink) Old 09-25-2009, 03:14 AM
I'd like to add that I left an old Gibson Les Paul Studio in a shed without strings on for OVER A YEAR (consider the wildly varying temperatures and humidity levels in the UK), and it didn't do it any harm whatsoever. Still has an action a smidge over 1/16th.
Now there is obviously an argument that the neck was a plank anyway so it doesn't matter, and an Ibby neck is obviously a bit more fragile, but you get my point.
Sickbean is offline
post #5 of 16 (permalink) Old 09-27-2009, 12:28 PM
To really do a good job to clean and treat your fretboard, I don't see anyway that you can do it without the strings off.
With the strings on, you can apply oil to the fretboard and wipe off but it doesn't clean as effective.
I occasionally use Ernie Ball Fretboard Conditioner on my guitars and then wipe off, or apply some Lemon Oil to a cloth and wipe on to the fretboard underneath the strings.
But it really isn't as effective as removing the strings.
jemeister is offline
post #6 of 16 (permalink) Old 09-27-2009, 11:25 PM
Yes, according to ibanez, it's best to change strings one at a time. This is correct, however it's also about the most impractical process in the world. How do you clean and oil your neck? How do you clean the dust and grime from between the pickups? You can't. The idea is that if you take the strings off all at once, there will be no tension on the bridge and it'll be a bit of a pain in the ass to get the guitar back in tune. It'll take you about 10 minutes atleast to get it stable again. However, if you just throw a 9v battery into the trem cavity so that the bridge is resting on the battery, this will keep your trem steady while you remove all the strings and do some housekeeping.
As Hell Broke Loose is offline
post #7 of 16 (permalink) Old 09-28-2009, 12:05 PM
Cant you just loosen the strings, undo the springs on the trem. Remove the whole bridge (inc strings) clean then replace trem. I think the main reason Ibanez say to do it 1 by 1 is less neck stress, more time saved when tuning!
crossbones is offline
post #8 of 16 (permalink) Old 09-28-2009, 12:33 PM
It's not so much about neck stress, it's about the time it'll take you to tune if you take the strings off all at once. By removing the bridge from the body, it's going to be an equally large pain in the ass to get yourself back in tune. Plus, you'll have to reinstall the trem.
post #9 of 16 (permalink) Old 09-28-2009, 05:07 PM
assuming that the springs are in the same formation, and the strings are the same, then you should be pretty much there when you tune each string to the original tuning. It won't take 15 minutes like if you took all the strings off.
In theory at least.
post #10 of 16 (permalink) Old 09-28-2009, 06:14 PM
In theory at least.
It works perfectly in real life as well, I always clean the fretboard that way:
Put it all back as it was and you're back in tune.
You can also undo the locking nut, if you've done that:
This is a bit more risky, as the posts may unwind by themselves slightly. But it does work.
eviltwin is offline
post #11 of 16 (permalink) Old 09-29-2009, 09:10 AM
I have also wondered if oiling the neck with the strings on will deaden the strings? I used to do this all the time and never had a problem. Just wondering, because I like to keep the rosewood necks moist...
metalgod72 is offline
post #12 of 16 (permalink) Old 09-29-2009, 09:35 AM
every time i restring (every 2-4 weeks) i block the trem and give the fretboard a good scrub. i just put a schweppes bottle lid under the trem (i have an EZ trem) and it keeps it almost 100% proper level. take off all the strings and have it.
so easy.
Homebake is offline
post #13 of 16 (permalink) Old 09-29-2009, 09:48 AM
It would probably make the strings a bit oily but that's about it!
Sickbean is offline
post #14 of 16 (permalink) Old 09-29-2009, 10:00 AM
every time after i play these days for a long period i run my finger along the whole string and get all the dirt off. helps you know.
Homebake is offline
post #15 of 16 (permalink) Old 07-21-2019, 08:24 PM
Most enterprises use ERP systems for monitoring and analyzing data. However, one of the biggest advantages of managemart ERP-system is the ability to improve the efficiency of the company by monitoring key performance indicators of employees. Using the ERP system as a centralization object requires that enterprises use both financial and non-financial indicators to set goals.
vbnosa is offline
cleaning/oiling fretboard
Just got a JS6! Need advice on cleaning it up / oiling Toadfish Ibanez JEM, UV, JS & Other Signature Models 12 08-30-2009 07:18 AM
Changing strings/cleaning fretboard on LP Standard jemeister All Other Guitars (including Prestige) 1 06-09-2007 11:26 AM
oiling fretboard JasonMalmsteen Tech: Setup, Repairs and Mods 36 01-29-2007 10:42 PM
Fretboard cleaning NeglectedField All Other Guitars (including Prestige) 10 05-30-2006 09:21 AM
fretboard cleaning Drache713 Tech: Setup, Repairs and Mods 2 09-17-2004 10:20 AM
