Coil-splitting on Ibanez ICT700 - Jemsite
post #1 of 4 (permalink) Old 05-17-2010, 06:27 AM Thread Starter
Hello,
as this is my first post here I want to introduce myself: my name is Alex, I'm 23 years old (playing guitar since 9 years, but I'm not nearly as good as I should be, made many breaks...) and I'm living in Vienna, Austria.
Recently I bought a used Ibanez ICT700, my question is if it's possibly to install a push-pull pot and split the standard humbuckers it came with (DiMarzio D Activators). I think I could check this easily by looking at the wires coming from the PUs, but I really have no clue on what to look for exactly
Thank you very much, and please excuse my English!
Best regards,
Alex
AlexFinger is offline
post #2 of 4 (permalink) Old 05-17-2010, 09:33 AM
Re: Coil-splitting on Ibanez ICT700
If the D Activators in ICT700s are exactly like the ones DiMarzio sells separately (and I wouldn't know why they shouldn't), they have four conductor wiring, meaning that it's possible to split them, for example with a push-pull pot.
Brambram is offline
post #3 of 4 (permalink) Old 05-17-2010, 10:07 AM Thread Starter
Mine have "DiMarzio" written on the surface of the pickup, I think on the right bottom, black on black. The D Activator-X I purchased separately doesn't have this, so I wondered if the PUs that come with the guitar are the same as the ones they sell.
So if I take a look at the cables coming from the PUs and there are four wires coming out, they can be split?
Best regards,
Alex
post #4 of 4 (permalink) Old 05-17-2010, 10:44 AM
Basically, yes: there should a be wire (usually the red one) going to the toggle and a wire (bare/green) to 'earth', probably the back of the volume pot. The two extra wires needed for coil-splitting (black white) probably are soldered together and taped off.
Brambram is offline
Coil splitting with INFS? necross_19 Pickups & wiring 1 10-22-2008 09:17 AM
coil splitting martyfriedman86 Pickups & wiring 0 10-14-2008 09:58 AM
Coil splitting EMG's? jbandy10 Pickups & wiring 5 06-01-2008 01:40 PM
Coil splitting linthat22 Pickups & wiring 4 01-25-2006 08:21 AM
V8 coil splitting problams.. Ibanez Junkie Pickups & wiring 3 11-07-2003 12:02 PM
