A Couple Questions - Jemsite
post #1 of 17 (permalink) Old 11-15-2006, 10:59 PM Thread Starter
A Couple Questions
Hi, I'm new to the site, and I have a few questions.
But first, let me state that I am left handed, and after a few months of "jamming" on an old acoustic, i decided to get serious. I found a left handed rg body on the bay a few months ago, and since then bought a neck, and electronics.
I still need a trem, tuners, pickups, pick guard , and nut. I am trying to buy the highest quality parts so i can have a guitar that will last me a long time. So here come the questions:
For the pickups, should I go straight ahead and go with dimazios, or just go with some these gfs pickups: http://store.guitarfetish.com/gfscrourhoov.html
Keep in mind I will probably be playing through a marshal half stack, because my sister's boyfriend wants to sell his.
For the pick guard, do you guys think of the quality of the monster guitar shop ones are good, or should I pay the extra 50 bucks for a pick guard paradise one?
Will any Gotoh tuners fit my Ibanez neck? BTW, its a 92 model.
And now it comes down to the trem. I am still deciding whether I want a edge or lo pro. I have no way to try out them, because I am left handed, and no guitar shops have older models. Can you guys give me the ups and downs?
Also, I am going to get a trem kit from Ibanez Rules, and I am wondering if it includes the nut, like in this picture from an Ibanez catalog, or if I have to buy it separately.
If I do have to buy a separate nut, I noticed Rich only has lefty nuts in cosmo, but my hardware is going to be black. Should I go with the cosmo nut, or convert a black righty nut to lefy. Will there be any problems if the e,b, and g strings have wider slots?
Sorry for the long post.
Bookshelf is offline
post #2 of 17 (permalink) Old 11-15-2006, 11:26 PM
Re: A Couple Questions
welcome to the site!
Email rich and Im sure he will tell you all you want to know about the edge kits. The edge and lo pro work prety much the same so just choose which ever one looks cooler to you.
You should be able to find some original ibanez gotoh tuners on evilbay. Definately go dimarzio if you can afford it.
crevis is offline
post #3 of 17 (permalink) Old 11-16-2006, 12:37 AM
+1
I'm pretty sure too that Gotoh tuners will fit.
As for the dimarzio of gfs question, it's really up to your taste (an ears!) what to choose (I choose dimarzio, but other guys might say seymour duncan etc.)
Good luck with the mods!
Aris_T is offline
post #4 of 17 (permalink) Old 11-16-2006, 09:28 AM
You can't convert a righty nut to a lefty. But you can get the nut you want from allparts.com (lefty).
Regards
André
fettouhi is offline
post #5 of 17 (permalink) Old 11-16-2006, 09:31 AM Thread Starter
Regards
André
Sorry, when i mean convert the nut, I mean I will grind the e,b, and g slots wider with a dremel so they will fit the d, a, and e strings. My only concern is the huge slot for the e and b strings
post #6 of 17 (permalink) Old 11-16-2006, 09:34 AM
That will be problem with the wider slot for the e and b string. Hence get a new nut from allparts or guitarsdepot (or whatever it is called) in the color you want.
Regards
André
fettouhi is offline
post #7 of 17 (permalink) Old 11-16-2006, 09:50 AM Thread Starter
Do you think I should go with one of these, or get a Cosmo nut from Rich. Do you know if there is any difference in quality between the two nuts because the ones from Rich cost 40 dollars more?
post #8 of 17 (permalink) Old 11-16-2006, 03:19 PM
I don't know on the quality of these but I think they should be fine. The nuts from Rich cost more because they original Ibanez parts . If you are unsure then get OFR nuts.
Regards
André
fettouhi is offline
post #9 of 17 (permalink) Old 11-16-2006, 03:48 PM
GilkyBear's Avatar
I would just get it all from Rich because A, he is going to be incredibly helpful as you progress, and B, you will get everything in the mail all at once and be ready to begin.
GilkyBear is offline
post #10 of 17 (permalink) Old 11-16-2006, 04:41 PM
Lefty Ibanez parts are not pick and choose, they're "I'll take whatever I can get". I have a nut, tuners, and trem bars, and that's it.
Rich is offline
post #11 of 17 (permalink) Old 11-16-2006, 06:35 PM Thread Starter
I know, I'm going to do the lefty conversion on the trem. Also, would I be able to order a right handed trem with a left handed bar?
post #12 of 17 (permalink) Old 11-16-2006, 06:47 PM
I have an origional lefty edge if you need it...just needs a bar and posts which rich has...
Lefty Robb is offline
post #13 of 17 (permalink) Old 11-16-2006, 10:37 PM
An R trem would have to have the arm holder drilled and tapped to move to L side.
Rich is offline
post #14 of 17 (permalink) Old 11-16-2006, 10:49 PM
Or get a U bar if your a korn fan
crevis is offline
post #15 of 17 (permalink) Old 11-17-2006, 08:02 PM Thread Starter
Thanks for all the info guys.
What do you think of the Monster Guitar Shop pickguards compared to the Pickguard Paradise ones? Do you think they are worth the extra $50?
Also, I need neck screws for a neck joint that uses a plate, and I want to know if I can use screws for an aanj, of if I should get them somewhere else.
arm holder , gotoh tuners , guitar shop , ibanez catalog , ibanez neck , neck joint , neck screws , pickguard paradise , seymour duncan
Similar Searches
what couple with x2n
A couple of tremolo questions... PacificaJonny Tech: Setup, Repairs and Mods 6 05-03-2006 12:26 PM
A couple questions concerning my rg350ex Jebus All Other Guitars (including Prestige) 1 05-04-2005 02:39 PM
JEM 2K DNA, Advice, a couple questions? PerpetualBurn Ibanez JEM, UV, JS & Other Signature Models 115 04-02-2004 09:07 AM
Couple of questions on the RG421 DKnight Tech: Setup, Repairs and Mods 8 04-15-2003 10:52 AM
My Mystery Ibanez - couple questions Scott 74 All Other Guitars (including Prestige) 9 09-18-2001 07:16 AM
