Couple of questions on RGA 121 NTF - Jemsite
post #1 of 2 (permalink) Old 04-30-2009, 08:01 PM Thread Starter
Greetings from London - my first post. I've just acquired a used but excellent condition RGA 121 NTF and like it very much. I do have a couple of questions though.
1. To perfect the intonation on the G string, I'd ideally like to give it another half turn or more on the bridge adjustment. However the moving part (saddle?) is at its maximum displacement and can't move any more. Any options here?
2. The volume control is well used and moves very easily at the slightest touch. Hence vigorous playing can result in unexpected volume changes. Any adjustments possible here to make it stiffer, or do I need a new pot? What size/taper is it?
Thanks!
dabbler121 is offline
post #2 of 2 (permalink) Old 05-05-2009, 07:49 AM
GAZ
Re: Couple of questions on RGA 121 NTF
Before adjusting intonation, always fit new strings and stretch them in well. Check/adjust the neck relief/truss rod and then the action followed by the intonation.If you still can't intonate the G string properly you either have to live with it or intonate all the other strings to match the G as long as it's barely noticable to the ear as opposed to a tuner !!! As for the volume pot try a felt washer under the volume knob to give a bit more resistance. Good luck !!
GAZ is offline
rga 121 ntf
Similar Searches
what couple with x2n
Couple of questions on pots etc. Cyrix Pickups & wiring 2 08-12-2007 01:06 PM
A Couple Questions Bookshelf All Other Guitars (including Prestige) 16 11-19-2006 06:40 PM
A couple questions concerning my rg350ex Jebus All Other Guitars (including Prestige) 1 05-04-2005 02:39 PM
JEM 2K DNA, Advice, a couple questions? PerpetualBurn Ibanez JEM, UV, JS & Other Signature Models 115 04-02-2004 09:07 AM
RG 570 CT - A Couple Of Questions CrossingStar All Other Guitars (including Prestige) 1 06-25-2002 10:55 PM
