Creaking S570 neck - Jemsite
post #1 of 1 (permalink) Old 12-03-2016, 07:16 PM Thread Starter
Creaking S570 neck
Hi all, I'm newly registered on Jemsite. I have an S570 which is set up correctly in terms of neck relief, action, etc. but it has a weird problem - the neck creaks whenever I use the whammy bar, up or down. From holding the neck, it feels like two or three loud creaks coming from inside at around fret 5. Strange thing is - it ONLY happens when the nut clamps and bolts are tightly in place on the strings. When they are removed and the string tensions run all the way up to the tuning pegs, the creaking doesn't happen (the guitar is properly in tune in both cases). I'm certain the nut is not loose - both fixing screws are tight. The neck is also tight in the body. It seems to me like the truss rod is kind of binding against the inside of the neck. Does this sound even possible? Should it really move? I wouldn't have thought so. Any other ideas what could be and how to fix it? Thanks.
B_Fella is offline
creak , neck , noise , s570
RG Swirl and NEW S570 Neck ozjem Classified Ads: Guitars and Gear 2 01-07-2013 12:37 AM
My S570 Neck Vs. Bridge Radius Vs. Action Discovery fly_with_v All Other Guitars (including Prestige) 0 03-10-2011 06:11 PM
aanj reattached... neck creaking noises bluffalo Tech: Setup, Repairs and Mods 4 09-28-2010 12:19 AM
creaking trem arm? Devon8822 Ibanez JEM, UV, JS & Other Signature Models 3 05-20-2009 05:28 PM
Creaking neck and Tuning instability LimHae Tech: Setup, Repairs and Mods 3 06-01-2003 11:50 AM
