creaky lock nut? - Jemsite
post #1 of 10 (permalink) Old 04-18-2008, 08:59 AM Thread Starter
creaky lock nut?
I just recieved a jem clone I had built, and when I dive the bar hard, I get a very noticeable creaking sound at the nut! It's an Ibanez RG neck, but the lock nut used was aftermarket, and I notice he used a shim underneath it. Would that be the reason for it? Anyone else ever have this problem, or have any tips to fix it?
JRJem79 is offline
post #2 of 10 (permalink) Old 04-18-2008, 09:11 AM
Re: creaky lock nut?
Sounds like the nut is loose - tighten it a little but not too much
markg5150 is offline
post #3 of 10 (permalink) Old 04-18-2008, 09:16 AM Thread Starter
checked that right away, and it was clamped down tight...any other ideas?
JRJem79 is offline
post #4 of 10 (permalink) Old 04-18-2008, 09:19 AM
I meant the screws holding the nut to the neck not the locking pads themselves.
post #5 of 10 (permalink) Old 04-18-2008, 09:29 AM Thread Starter
sorry, that's what I meant too!
JRJem79 is offline
post #6 of 10 (permalink) Old 04-18-2008, 11:03 AM
does it moves in place? can you see it while you dive the bar?
nuno is offline
post #7 of 10 (permalink) Old 04-18-2008, 11:19 AM Thread Starter
I can't see it moving when I dive bomb, and I certainly can't wiggle it by hand or anything, the screws are in there tight. Is there something different about the fit of an Ibanez lock nut as opposed to others? I'm wondering if the problem is the fact it's shimmed, or is that a common thing?
JRJem79 is offline
post #8 of 10 (permalink) Old 04-18-2008, 11:25 AM
They're all shimmed. You need to be able to adjust the height of the nut, that's how it's done.
heffergm is offline
post #9 of 10 (permalink) Old 04-18-2008, 11:31 AM
Does your tuning go off? Sounds like the noise a slipping string makes.
moebius is offline
post #10 of 10 (permalink) Old 04-18-2008, 11:43 AM Thread Starter
No, it holds tune well, I don't think the strings are slipping, its like you can feel it in the neck when it creaks....I don't see it shifting though, and its screwed down tight.
JRJem79 is offline
lock nut
Lost STRING LOCK BLOCK : need a replacement urgently Incommunicado Tech: Setup, Repairs and Mods 10 09-26-2011 06:29 AM
Lo Pro Bridge Stud Lock Screws? ed3120 Tech: Setup, Repairs and Mods 3 01-13-2007 11:55 AM
Adding guitar lock for strap help? grant862 Tech: Setup, Repairs and Mods 1 10-15-2005 06:27 PM
Adding guitar lock for strap help? grant862 Ibanez JEM, UV, JS & Other Signature Models 0 10-15-2005 03:54 PM
edge spring block lock, does it affect tuning stability satchman Tech: Setup, Repairs and Mods 5 03-03-2003 09:21 PM
