Custom cut out - Jemsite
post #1 of 17 (permalink) Old 05-02-2012, 04:14 PM Thread Starter
KMT
Custom cut out
I bought an RG350dx a while back that has been totally customized. I'd like to know your opinions on its value. The neck is all orig. The body has been refinished (more on that..) and cutout with a custom monkey grip. The cutout looks well done and I've used it enough to trust it is solid. The finish is a gray color texture paint... almost like fake stone or rhino lining. Why? No idea. It's unique tho! The pickguard is custom fabricated, circualr brushed aluminum. Pickups are humbucker size P90 neck, hot single middle (he claimed its a texas special, sounds like but not fender.) and a charvel PAF bridge. electronics are 1 volume pot and upgraded selector switch. Hardware is original.
I'll post pics tonight, but with that info, any guesses on what that does to the value?
KMT is offline
post #2 of 17 (permalink) Old 05-02-2012, 04:36 PM
RGTFanatic's Avatar
Re: Custom cut out
Pics will help but, unfortunately, the hardware on the guitar will be your limiting factor.
I'm assuming your guitar is a 2010 or older. If it is, you'll have an EdgeIII, Edge ProII, Lo-TRSII, or other low end bridge. Regardless of other upgrades, the trem,nut, and tuners will keep it's resale value in the same area as a stock 350 of the same year and condition.
RGTFanatic is offline
post #3 of 17 (permalink) Old 05-02-2012, 05:09 PM Thread Starter
KMT
Re: Custom cut out
Thanks for the insight! I've noticed that's what people are mostly after. I believe the trem is an edge iii on that model but I could be wrong (I'm at work otherwise i'd check) Best to part it out then??
KMT is offline
post #4 of 17 (permalink) Old 05-02-2012, 05:28 PM
Re: Custom cut out
A guitar that weird is one to play if you like it, and pass on if you don't. There's no reason to assume you're going to turn any kind of profit parting it out, because you likely won't. Especially with no real info on what pickups are now in it.
GuitarBizarre is offline
post #5 of 17 (permalink) Old 05-02-2012, 07:34 PM
RGTFanatic's Avatar
Re: Custom cut out
+1
You'd probably do better selling it as a whole. The only parts on a guitar that are really worth significant money are the neck and hardware. Neither your neck or hardware will fetch much on their own.
If it were my guitar, I'd route it for an Edge/Lo-Pro, find a decent, but inexpensive trem, nut, and tuners.......then keep it.
post #6 of 17 (permalink) Old 05-02-2012, 10:38 PM Thread Starter
KMT
Re: Custom cut out
It's built with an edge two and has a cool neck but I like my S520 more for the tone and playability, and the zr trem is way easier to maintain and tune. I don't really need both guitars. So your opinion is to sell it whole? I may snatch the PAF from it... it's better than the INF bridge in the S520.
Thanks for the input.
KMT is offline
post #7 of 17 (permalink) Old 05-03-2012, 12:37 AM
RGTFanatic's Avatar
Re: Custom cut out
No Problem. Judging by another post, you got the 350 for a decent price, you should be able to make a couple bucks off of it even with the INF in it.
post #8 of 17 (permalink) Old 05-03-2012, 11:00 AM Thread Starter
KMT
Re: Custom cut out
Yeah I'll do okay. I still have 1 hickup. The finish is ugly and I gotta fix that. Might even keep it if I can get it lookin nice. Are there any good tutorials here about refinishing? The 350 is basswood, I don't know if that matters.
KMT is offline
post #9 of 17 (permalink) Old 05-03-2012, 12:10 PM
Reviews: 9
Re: Custom cut out
See here http://www.projectguitar.com/
Bascally,
Sand smooth and flat (I do not use paint strippers), heaviest grit needed, then reducing grit several times as removal is completed.
Depending on the your desired result you may need filler or a base coat.
Use light coats if using cans, keep cans in warmer area, do not spray in rain or heavy humidity.
I like to sand after most of the new color is down, then put some final color before beginning clear, it give a more consistant surface.
DRY,DRY,DRY
Sand clear to smooth (no shinney spots), polish.
fly_with_v is offline
post #10 of 17 (permalink) Old 05-03-2012, 02:44 PM Thread Starter
KMT
Re: Custom cut out
wow, thanks! that's easy, just handle with care!
KMT is offline
post #11 of 17 (permalink) Old 05-03-2012, 03:54 PM Thread Starter
KMT
Re: Custom cut out
OK. Here are picks for those of you that are curious (if there is anyone haha) Hopefully you can see the texture in these pics.
KMT is offline
post #12 of 17 (permalink) Old 05-03-2012, 07:28 PM
RGTFanatic's Avatar
Re: Custom cut out
I'd probably leave the body as-is.........it actually looks decent. Put a black pickguard and matching pups on it and it will look great.
If that paint is the garage floor epoxy that it looks like, it will be a MONSTER to remove. Epoxy paint turns to goo when you try to sand it....clogging your paper/disc's.
post #13 of 17 (permalink) Old 05-03-2012, 08:51 PM Thread Starter
KMT
Re: Custom cut out
I don't think the paint is epoxy. It's very rough, lumpy even. I can chip it off with my thumbnail.
KMT is offline
post #14 of 17 (permalink) Old 05-03-2012, 08:58 PM
RGTFanatic's Avatar
Re: Custom cut out
Obviously whoever painted it did a bad job if you can take it off that easy. Maybe you can scrape it off with a plastic scraper then??? see what the paint underneath it looks like.
post #15 of 17 (permalink) Old 05-03-2012, 09:07 PM
Re: Custom cut out
It's called Fleck-Stone you can buy it from Walmart. kinna cool
LuredMaul is offline
custom , grip , jem , rg350
Petition to open a Semi-Custom Shop based upon J.Custom. mrpanoff Comments to Ibanez 56 10-28-2015 08:41 AM
FS: Jackson Custom Shop Telly Custom Amber Sunburst one of a kind Ambitot Pu Phang Classified Ads: Guitars and Gear 0 05-02-2008 01:19 PM
