diffencences between GIO, PREMIUM, Prestige? - Jemsite
post #1 of 22 (permalink) Old 04-23-2011, 06:37 AM Thread Starter
I would like to know what's the difference between GIO, PREMIUM, Prestige and standard (Ibanez alone) guitars.
enb141 is offline
post #2 of 22 (permalink) Old 04-23-2011, 05:40 PM
Re: diffencences between GIO, PREMIUM, Prestige?
The Gio is made with the lowest quality products the cheapest way possible. The Premium, and Prestige from my understanding is made the same way one is just made in Indonesia, and one is made in Japan. The Standard line is middle of the road, not the best but not the worst.
jimistephen is offline
post #3 of 22 (permalink) Old 04-23-2011, 09:16 PM
RGTFanatic's Avatar
impossible question to answer.......... What guitars in particular do you want to know about?
RGTFanatic is offline
post #4 of 22 (permalink) Old 04-23-2011, 10:01 PM Thread Starter
RG370DX, GRGA42TQA and GRGA32T
enb141 is offline
post #5 of 22 (permalink) Old 04-23-2011, 10:06 PM
Reviews: 11
guys, whats the difference between a toyota corrolla and a Ferrari 458 italia?
linuxpenguin is offline
post #6 of 22 (permalink) Old 04-23-2011, 10:07 PM
RGTFanatic's Avatar
The Ferrari is red????
post #7 of 22 (permalink) Old 04-23-2011, 10:14 PM Thread Starter
Toyota corolla:
1.8 Litter 16-Valve -4 Cylinder, 132HP, 5 speed
458 Italia
4.499 Litter, V8, 560HP, 7 speed.
enb141 is offline
post #8 of 22 (permalink) Old 04-23-2011, 10:45 PM
RGTFanatic's Avatar
that makes it a little easier.......
GRGA32T-
NECK: GRGA profile (25.5"scale, 43mm nut, 56mm heel, 20.5mm thick at 1st fret and 23mm at the 12th, 400mm fretboard radius) this thing is a baseball bat with frets....lol. I think it's one piece maple construction with a rosewood board, but I can't confirm that.
BODY: Multi piece Mahogany laminate. the last one I looked at was at least three piece..(you could see the joints in the finish)
Electronics: unknown, but rest assured they are the cheapest Ibanez could find.
Pickups: STD H1/H2..... I can't find any info on these, but see electronics above for what I'm sure their quality level is....expect to replace them immediately.
Bridge: Double locking Edge III- the only redeeming quality of this guitar, and that's not saying much.
GRGA42TQA- Same guitar as the GRGA32T except that the body is basswood, it has a "Photo Quilt" top, and has real EMG passive pickups. this guitar is a nice upgrade from the 32, but still an "entry level" guitar.
RG370DX-
Neck:
Wizard III- 3-piece maple construction with Wiz3 profile (25.5" scale, 43mm nut, 58mm heel, 19mm at first fret, 21mm at the 12th, 400 mm radius), bound rosewood fretboard with sharkstooth inlays and jumbo frets.This is a much more playable neck than the GRGA above (subjective- but pretty realistic)
Body: Multi piece basswood construction with much better attention to prep for finish (better sealer/primer coats)
Electronics: all the examples I've seen have had the ym-50 switch and nice pots (I don't know who made them though)
Pickups: Ibanez INF series.... not a "great" pup by any means, but theyre sufficient for a beginner, otherwise expect to change them out.....They DO sound better than the H-series on the GRGA32....
Bridge: If you get the orange one you'll get a very nice surprise with the Edge Zero II bridge. It's the same bridge that's on the Premium series RG's. other colors (black and white) will have the Edge III.... see above for that.
post #9 of 22 (permalink) Old 04-24-2011, 12:14 AM
Reviews: 3
Actually, all the indo rgs now have ezll, at least in canada.
IBZshredder is offline
post #10 of 22 (permalink) Old 04-24-2011, 12:57 AM Thread Starter
GRGA32T-
RG370DX-
Neck:
That's what I was looking for, thanks.
Now back to the topic what I'm looking for this guitars is to mod them specially the Neck, I want to upgrade the neck with a moses one, change pickups with air norton + tone zone or something in that price range, also the electronics but what I most likely care is the design, wood and bridge.
I was thinking to get one of this cheap guitars or build a warmoth body with a price closer to this guitars.
Now one more question, you said that those guitars are multi piece rosewood / mahogany so do you know if warmoth bodies (soloist) are one piece or are multi piece?
So do you know if higher class ibanez guitars like RG3770Z are single piece bodies or are them multi piece too?
enb141 is offline
post #11 of 22 (permalink) Old 04-24-2011, 01:41 AM
You will be hard pressed to find any guitar maker using a one piece body today. The wood stock just doesn't exist anymore.
musikron is offline
post #12 of 22 (permalink) Old 04-24-2011, 01:49 AM Thread Starter
I see, so multipiece is a norm in all guitar makers / models.
enb141 is offline
post #13 of 22 (permalink) Old 04-24-2011, 06:51 PM
Reviews: 11
Dude, if you are going to replace the neck, pickups, and all electronics, you are far far far better off buying a cheaper edge based guitar. Id HIGHLY suggest you get an rg570. They can be had for dirt cheap and come with all the features you need in a high quality guitar. Do NOT buy an expensive guitar and tear it apart, it just doesnt make sense lol.
and yes, multipeice bodies are the norm, and its ok. 2 peices of wood glued together is much much stronger then a single piece of wood actually.
post #14 of 22 (permalink) Old 04-24-2011, 11:12 PM Thread Starter
I did that in the past, I bought an used guitar and after all the guitar was good but I'm too picky so to me a brand new guitar is a must and it seems that the RG 570 has been discontinued.
The only models that I can see on ebay are those RG470AH.
In other words I'm looking for a mint zero scratches body.
enb141 is offline
post #15 of 22 (permalink) Old 04-24-2011, 11:21 PM
Reviews: 11
There ARE some mint condition bodies floating around. If anything, buy a body from one of our vendors and have them paint it to your specs you want. Save you some coin. No sense buying a brand new guitar and tear it apart lol.
gio , premium , prestige
Ibanez Premium S ? erasetheprocess All Other Guitars (including Prestige) 26 01-13-2012 06:44 PM
NGD--Premium RG920QM AlaskaBat All Other Guitars (including Prestige) 111 04-13-2011 01:41 PM
RG920QM Premium or RG3120? jclogston All Other Guitars (including Prestige) 23 03-17-2011 12:15 PM
WTB: Xbox 360 Premium Tragical Classified Ads: Guitars and Gear 0 12-26-2007 03:48 AM
Premium popping corn? jay ratkowski Off-topic / Miscellaneous 16 07-30-2007 10:10 PM
