Difference between RG8570 and 8670? - Jemsite
post #1 of 12 (permalink) Old 04-17-2005, 08:21 AM Thread Starter
Smile Difference between RG8570 and 8670?
Can anyone tell me the difference between the RG8570 and 8670?
Thinking about buying one of them.
Eddie88 is offline
post #2 of 12 (permalink) Old 04-17-2005, 09:10 AM
Re: Difference between RG8570 and 8670?
8670 has the J-Custom tree of life inlay on the neck. That's the only difference i think. Oh and one of the 8570 colour options has a lovely maple fingerboard.
They're both amazing guitars.
Andelusion is offline
post #3 of 12 (permalink) Old 04-17-2005, 10:47 AM
8570 has a thicker and narrower neck...
Flanker is offline
post #4 of 12 (permalink) Old 04-25-2005, 05:57 AM
Yes...I do have a 8570MTB...lovely maple fingerboard. A great neck. Much thicker and alittle narrower. Definitely great feel. I had a chance to try out a 8670 before deciding on 8570. 8670 neck is alittle too thin for me. Was a great choice going for 8570.
teof is offline
post #5 of 12 (permalink) Old 04-28-2006, 02:10 AM
ok, it's just me or what.
i've got 8570, swaped the pickups into duncan Distortion bridge and neck, in the middle is litlle 59.
the original line up : tone zone, blue velvet- air norton did not please me well.
the reason I changed the PUs was I found the tone is too muddy, not mentioning that it was very smooth and 'polite' distortion with the original Pus, i thought it was the tone zone, I never like yone zone anyway, so i changed it.
now, with duncan, there is an improvement, but still muddy.
I compare to other Rg with basswood and same pickups ( duncan distortion), the basswood produce more gain and brighter sounding than the 8570.
Is it because of the maple top on the 8570 or do I have trouble with the potentio or something?
the output on 8570 is ok, there is no problem on the output.
psychoshredder is offline
post #6 of 12 (permalink) Old 04-28-2006, 06:01 AM
Try changing the bridge pups with Air Zone. It will sound really good. Dont know about the rest of the positions.
TongueShredder is offline
post #7 of 12 (permalink) Old 04-28-2006, 06:48 AM
Compared to a mahogany guitar?
bpd111 is offline
post #8 of 12 (permalink) Old 04-28-2006, 08:43 AM
The RG8670's also have an ebony fretboard. I don't own an RG8570, but I do own an RG1880 which is essentially the same guitar with a Lo-Pro bridge. I find both necks(rg8570 and rg8670) to be very comfortable but some people do find the thicker J-Custom necks(like the 8570 spec'd ones) to be a little too thick.
You can't go wrong with either one really.
buddroyce is offline
post #9 of 12 (permalink) Old 04-28-2006, 10:02 PM
yeah, my 8570 is rosewood, somehow thicker than the original wizard neck.
but it doesn't bother me.
This is the first time for me to put distortion duncan into mahogany body, so I don't have any experience before.
I'm sure that the tone on my 8570 is way too different from other RG i own.
I put Screaming demon on the 1550 limited edition with mahogany body also, and it sounds bright.
Then I have a custom 5 duncan on the RGR 580, also mahogany body, and it sounds bright too.
the above guitars are mahogany with no laminated top, only 1550 Fm has veneer, I don't think veneer will change the tone significantly.
But this 8570 is not the way I'm expected, it sound mud, polite, smooth distortion, even with the duncan distortion which I know as the 'beast' in the duncan line up.
so i'm blamming on the maple top on the 8570.
post #10 of 12 (permalink) Old 04-29-2006, 03:06 PM
rg8670: vine of life, ebony fretboard, thinner neck (don't think it's narrower, they're both 43mm).
rg8570: off centre dot inlays, rosewood board, thicker neck.
and they're both available in different colours.
dave_mc is offline
post #11 of 12 (permalink) Old 04-30-2006, 01:11 AM
43mm is the radius, not the neck "depth" or "width"
Ibateur is offline
post #12 of 12 (permalink) Old 04-30-2006, 07:42 AM
^ 43 mm (1 11/16") is the width of the nut.
the radius is normally around 430 mm (just over 17") on the prestige/j custom rg's.
dave_mc is offline
air norton , bridge pup , custom necks , dot inlay , dot inlays , duncan distortion , ebony fretboard , mahogany body , maple fingerboard , rosewood board , tone zone
WTB 8670 sroyboyk Classified Ads: Guitars and Gear 2 05-22-2007 10:47 PM
VWH Vs. 8670 phlame All Other Guitars (including Prestige) 28 10-19-2005 04:47 AM
Stress Crack on my 8670 kennydoe All Other Guitars (including Prestige) 25 09-08-2005 10:22 AM
FS: RG 8670 J-Custom disassociative1 Classified Ads: Guitars and Gear 2 08-04-2005 04:51 AM
7dbk or RG 8670-TB Bezial All Other Guitars (including Prestige) 4 11-05-2004 05:28 AM
