Different quality guitars in different countries (RG Prestige) is this possible? - Jemsite
post #1 of 10 (permalink) Old 03-21-2012, 02:25 PM Thread Starter
My brother has an Ibanez RG 2550z Prestige bought in Romania, this guitar has been barely played, let's say in a year and a half it gets played one hour a month, and it's already showing signs of fret wear.
It never left the house, it's probably only the 3rd set of strings that's on it, including the one that came from the factory, and it's always been 9-42 Ernie Balls, so nothing heavy and nothing abrasive.
I had an Ibanez RG 270 bought from the UK, which I played a lot for 7 years and had no major fret wear...
My brother's main guitar is an SZ 520, which has been bought in Australia and is also 7 years old, again, no major fret wear...
He uses 9's on the SZ, but that guitar used to be mine so I used 10's and 11's for probably 4 years or so... without any noticeable fret wear
So is this possible that lower quality guitars are sold as premium guitars in different countries?
Acoustically and build wise the 2550 is pretty much awesome, but how come the frets wear off so quick?
You can't say it's a dud because the wood is awesome, and frets are frets, you don't have dud frets unless you make them out of a lesser alloy....
What is your opinion on this?
Regards,
Andrei
AndreiPopa is offline
post #2 of 10 (permalink) Old 03-21-2012, 03:29 PM
RGTFanatic's Avatar
Re: Different quality guitars in different countries (RG Prestige) is this possible?
It is possible to have "bad" fret-wire. if the metallurgy isn't quite correct or the annealing process was not done correctly.
I don't think this is likely in your case though. My guess would be the old strings on the guitar. Regardless of the amount of times they're played, strings start to degrade the second they're taken out of the packaging. The corrosion they build from sitting for weeks at a time is probably what is wearing on the fret-wire.
RGTFanatic is offline
post #3 of 10 (permalink) Old 03-21-2012, 03:33 PM Thread Starter
Could be, but why hasn't it happened on the other guitars?...
post #4 of 10 (permalink) Old 03-24-2012, 01:18 PM Thread Starter
The word corrosion that you mentioned got me thinking, my brother has sweaty hands and very corrosive sweat.
The bridge on the SZ, which is his main guitar, would make any Mad Max Art Director proud, it's a brownish-reddish decayed thing, instead of chrome, because of this sweat...
I did check the frets on the SZ, which I haven't done in a while, and they're pretty used...
Can this quick eating of the frets be done by the corrosive sweat?
Is it possible that even if he played the RG just a bit, the acid sweat could have caused the slight fret use in such a short amount of time?
post #5 of 10 (permalink) Old 03-24-2012, 03:18 PM
In answer to both questions, yes.
A friend of mine has very corrosive sweat and after a very short time his strings turn completely black and one of his Fenders, that's only a couple of years old is almost to the point of needing a good level. He plays with fairly high action so he can get away with it a bit, but...
He washes his hands before he plays, wipes down the guitar after playing and is very steadfast about it, but it's his sweat and there's nothing he can do about it, really.
I have a 22 year old RG550 that's never had a fret job or even a level (and I think only twice in it's life have I polished the frets) and it still is just fine. A few buzzy spots but nothing that comes through the amp, even clean, so I figure the old adage fits here, "If it isn't broken..."
But I have very little salt or acid in my sweat, so I'm lucky that way.
MicJustMic is offline
post #6 of 10 (permalink) Old 03-24-2012, 03:46 PM
I heard some woman use botox to their sweaty hands, downside is numbness
I also have sweaty hands, after cleaning I rub alcohol (actually Turkish lemon cologne, it has something like %80-90 alcohol in it) in my hands and that really extends the dryness.
mertay is offline
post #7 of 10 (permalink) Old 03-24-2012, 04:05 PM
Reviews: 21
My RG1570 and RG20th were built close to the same time I believe. The RG20th frets showed signs of wear much faster than the 1570; though honestly I'd say I played the 20th for, say, seven days for every four I've played the 1570. The 1570 to this day isn't showing much signs of wear. I think it might depend on the model or production run.
Oddly enough my RG3EXQM built in '06 shows the least amount of wear and I do play it about as much as the Prestige models.
mike570 is offline
post #8 of 10 (permalink) Old 03-24-2012, 04:07 PM
Doesn't seem like a good idea for a musician.
post #9 of 10 (permalink) Old 03-26-2012, 12:46 PM
GAZ
Things that can accelerate fret wear :
Fret buzz
Dirty strings
Old strings - Stainless steel strings wear frets fastest, but on nickel ones once the plating has worn away they're almost as bad as stainless !!
A very heavy handed technique
Corrosion
GAZ is offline
post #10 of 10 (permalink) Old 03-26-2012, 02:47 PM
Fret buzz
Dirty strings
Corrosion
Agree.
+ the alloy the frets are made of.
But that goes for all the hardware on the guitar.
I think the guitar just had a "bad fret day" when being build.
Death.by.G-string is offline
different quality , quality control , rg prestige
Prestige fretwork quality johnnyninja All Other Guitars (including Prestige) 5 11-10-2010 10:38 PM
What is the best quality non-prestige SB Ibanez Johnny Morales All Other Guitars (including Prestige) 2 05-29-2008 01:19 PM
Which are the hight quality best value guitars? NRS All Other Guitars (including Prestige) 29 12-08-2006 04:42 PM
Fret quality on Prestige neck? lloop9 All Other Guitars (including Prestige) 5 09-27-2004 10:12 AM
What are some excellent quality guitars? - Under $2000 Given to Fly All Other Guitars (including Prestige) 17 11-20-2001 01:03 AM
