Do the edge 3s sucks - Jemsite
post #1 of 5 (permalink) Old 06-10-2008, 01:03 AM Thread Starter
On the new rg models
i dont like em\
wondering on your guys opinion
i wish they still put the lo-pro edge on the Rgs that would be killer
alecmm61 is offline
post #2 of 5 (permalink) Old 06-10-2008, 02:04 AM
Re: Do the edge 3s sucks
i think they suck if you want perfect tuning stability
but with some good setup it can be played and used with little problems
-Rhaab is offline
post #3 of 5 (permalink) Old 06-10-2008, 02:12 AM
mi2tom's Avatar
If Ibanez were to put better trems in the lower end Rg, Ibanez will be stocking up high end ibanez guitar in their factory. IMO they aren't bad, any trems if set up properly will work great.
mi2tom is offline
post #4 of 5 (permalink) Old 06-10-2008, 02:36 AM
on the Edge-III (and EdgePro-II) the main problem is not the trem itself or its tuning stability, but the arm getting lots of "play" within a couple divebombs, no matter how you tighten it. i can't get why Ibanez doesn't take lessons from Wilkinson's trems. they're mostly insert-in arms yet they won't get any play ever.
nuno is offline
post #5 of 5 (permalink) Old 06-10-2008, 04:11 AM
SeanB's Avatar
I've never had any problems with mine apart from the usual problems that go with any floating tremelo system.
My guitar keeps in tune for a very long time with only minor tweaking now an again. I don't use the bar often...but I also don't keep the locking nut clamped.
People are too quick to hear what other people say on forums and just make that their own opinion. It's not bad if you get it set up right.
SeanB is offline
edge pro to lo pro rya Ibanez JEM, UV, JS & Other Signature Models 54 11-11-2012 03:24 PM
edge 3 to lo pro edge hoockey All Other Guitars (including Prestige) 16 11-22-2006 04:15 AM
Can I use Edge posts with an Edge Pro?? PatrickSimsCustomShopUSA Tech: Setup, Repairs and Mods 8 10-26-2006 10:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro MetalZone All Other Guitars (including Prestige) 21 10-24-2006 07:59 AM
Edge III Mystery... Solved? eclecticmage Tech: Setup, Repairs and Mods 47 10-22-2006 12:08 PM
