Down Tune - String Guages - Jemsite
post #1 of 16 (permalink) Old 06-04-2001, 08:11 AM Thread Starter
My brother wants me to set up his 6-string like a 7-string minus the high e. *What string guages should I use? *He'll probably tune down to A (a la Korn).
Two hands31 is offline
post #2 of 16 (permalink) Old 06-04-2001, 09:18 AM
Down Tune
try a set of 7-strings(low string a .056 or thicker) from ernie ball, or d'addario and minus the high string. then if he doesn't like it, choose a more appropriate set next time.
Getthis is offline
post #3 of 16 (permalink) Old 06-04-2001, 10:25 AM
lwi
Down Tune
Isn't this going to cause too much tension on the neck? *I mean a six-string usualy isn't setup to handle those string guages... But if your brother tunes it down to A it would ease the tension, and then you can forget about what I said
lwi is offline
post #4 of 16 (permalink) Old 06-04-2001, 01:40 PM
Down Tune
Try a light top heavy bottom set.
Noodles is offline
post #5 of 16 (permalink) Old 06-04-2001, 02:20 PM
Down Tune
twohands31 said:
* * "My brother wants me to set up his 6-string like a 7-string minus the high e. *What string guages should I use? *He'll probably tune down to A (a la Korn)."
if twohands really meant "set up" then it should be fine to use a set made for 7-strings sans the high e, and set up the guitar. if your just throwing on a set of strings to downtune then you will still have to set up the intonation, neck bow, and string action adjustments. that is unless he is going to just play korn songs, then it doesn't matter, does it?
Getthis is offline
post #6 of 16 (permalink) Old 06-04-2001, 05:06 PM Thread Starter
Down Tune
lol, that's funny, ESPECIALLY since I am a Korn fan. *I would love to hear a Korn style band with Vai style solos (a la the jam sessions they did). *He would be playing some Korn, but also some of his own music. *I've never adjusted the neck, but could do the intonation. *How would I adjust the neck?
post #7 of 16 (permalink) Old 06-04-2001, 06:39 PM
Down Tune
check jemsite.com or ibanez.com's help/tech sections for all about setting up. well ibanez guitars at least but setups on other guitars shouldn't differ too greatly. the neck shouldn't be a too much of a problem as long as the new string tension isn't much tighter than the old string tension.
what is the guitar anyways?
Getthis is offline
post #8 of 16 (permalink) Old 06-04-2001, 06:51 PM Thread Starter
Down Tune
Squire Strat
post #9 of 16 (permalink) Old 06-04-2001, 07:09 PM
Down Tune
Try here.
Noodles is offline
post #10 of 16 (permalink) Old 06-04-2001, 08:11 PM Thread Starter
Down Tune
Thanx everyone!
post #11 of 16 (permalink) Old 06-07-2001, 01:22 AM
Down Tune
I did that with my RG450 and just the other day while checking it out for stripping more parts, I noticed the receiving cavity post for the trem post was pulled towards the neck some. *Actually made some progress thru the wood in the body. *Not good.
I'd reconsider doing that to the guitar if I were you.
tomizm is offline
post #12 of 16 (permalink) Old 06-07-2001, 07:06 PM
Down Tune
Although he didn't detune really, SRV I understand used a .60 gauge string for his low E on his strats (and he was known to solo) so I don't think thicker strings will necessarily be bad for a guitar if properly set up, especially if it is detuned (where the strings are more floppy). I've used that same gauge as SRV (just minus the talent) on my 6 string ibanez' with NO problems, and NO string breakage.
mmr7 is offline
post #13 of 16 (permalink) Old 06-08-2001, 10:43 AM
Down Tune
Before I started playing 7-strings, I use to tune my 6-string down to B. *I suggest trying a set of D'Adarrio EJ22's. *They're gauged from 13-56 and they seemed to do the trick quite well.
revsharp777 is offline
post #14 of 16 (permalink) Old 02-24-2002, 06:25 PM
Down Tune
I agree with Rev......56 is a good gauge for a low B or A. Good rule of thumb is that standard should be 10's and every step below that you should go up one gauge on the strings
Sevenstringer is offline
post #15 of 16 (permalink) Old 02-24-2002, 11:20 PM
Down Tune
lwi on 10:25 am on June 4, 2001
If you put heavier strings on a guitar and keep it tuned to the same pitch, then yes, you're going to have problems. Put heavy strings on and tune down, and the effect is pretty much canceled out. With the right gauge and tuning combination, you'll end up with almost the same tension as a standard-tuned 6 string with 9's or 10's.
darren wilson is offline
ernie ball , ibanez guitars , neck bow , squire strat , string breakage , string guage , string guages , string tension
Your string guages are wrong! Dino Gear, Equipment, Recording & Off Topic 238 05-05-2008 06:34 PM
Tuning Down and String Guages slugman Tech: Setup, Repairs and Mods 7 09-06-2005 05:08 PM
whats string guages does the rg1527 come with nabeelm All Other Guitars (including Prestige) 2 06-10-2004 06:05 PM
String Guages - Driving my NUTS! Two hands31 All Other Guitars (including Prestige) 1 07-15-2001 12:25 PM
String Guages - I'm well stuck in my rut! Devo Ibanez JEM, UV, JS & Other Signature Models 20 06-21-2001 01:17 AM
