Drop C tuning on my S540...string guage? - Jemsite
post #1 of 10 (permalink) Old 06-10-2006, 08:40 PM Thread Starter
Question Drop C tuning on my S540...string guage?
I have 9's at standard tuning currently. I would like to make the minimal amount of adjutments to the trem springs, truss rod, intonation, etc. It has the wizard I neck (thin neck). I would also like to be able to purchase a "standard" set of strings which are readily availible (D'addirio or GHS). I'm thinking 10's or 11's. I can't imagine 12's on that guitar. I have 3 springs in the standard parallel configuration. I don't want to add a spring. I'd prefer to keep the parallel setup, but an arrow setup isn't out of the question.
Basically, I want to offset the required tension for the trem by selecting the best gauge string at drop C tuning.
So what do you guys think? 10's, 11's?
I'd also consider a tremelno down the road for this guitar.
BTW...it's an original edge trem.
S-man is offline
post #2 of 10 (permalink) Old 06-10-2006, 08:51 PM
Re: Drop C tuning on my S540...string guage?
10's by far
Eddie_UV777 is offline
post #3 of 10 (permalink) Old 06-10-2006, 09:43 PM
I would sure use 11's for Drop C on an Edge-equipped guitar, 12's for a fixed bridge. You could probably get away with 10's, but you're probably going to be adjusting the spring claw a bit at that point.
djohns74 is offline
post #4 of 10 (permalink) Old 06-11-2006, 12:11 AM
I personally use 11's for Drop C (Ernie Ball Power Slinky's) but then I like the feel of 10s in standard. If you want the feel of 9's in standard then you're probably going to want to go with 10's or maybe a custom gauge with thicker bass strings and thinner high strings.
lyconxero is offline
post #5 of 10 (permalink) Old 06-11-2006, 12:39 AM
Dee
11's.
Dee is offline
post #6 of 10 (permalink) Old 06-11-2006, 08:28 AM
I have 11-56 guage strings on my 540 tuned to C# standard. I would get a 10-52 set and a single 58 for drop C, but that's just me.
toshiro is offline
post #7 of 10 (permalink) Old 06-11-2006, 11:31 AM Thread Starter
Thanks for the responses.
I think I'm going to try this....
D'addario EXL 110-7 ...... 10-13-17-26-36-46-59/56
Strings for a seven....I just won't use the 26
The 59/56 is a discrepency between the packaging shown on the D'addario web site and the packaging that appears on the guitar center web site.
Same EXL 110-7 package shows 59 on D'addario website and 56 on guitar center website. They are the same EXL 110-7 package, but show a differant gauge. What's up with that? Wierd.
Anyway, as a point of referance:
D'addario EXL 140's are ....... 10-13-17-30-42-52
GHS ZAKK WYLDE's are........ 10-13-17-36-52-60
D'addario EXL 110-7 are....... 10-13-17-26-36-46-59/56
The EXL 110-7's seem like a nice compromise.
I'll give "my opinion" when I'm done.
S-man is offline
post #8 of 10 (permalink) Old 06-11-2006, 11:56 AM Thread Starter
FWIW here are the pictures of the packaging.........
S-man is offline
post #9 of 10 (permalink) Old 06-11-2006, 12:30 PM
Hmm, I think D'add recently upped all the low B string guage in their 7 string sets, so that might be what's causing the strangeness?
Sounds like a good plan though.
toshiro is offline
post #10 of 10 (permalink) Old 06-12-2006, 08:10 PM Thread Starter
Well...It worked out ok.
I set the (3) 16 year old stock springs in an arrow pattern. I had to crank the claw pretty far...still a little room. Adjusted the bridge for decent action...had to crank that down pretty far... too.
I still need to tweak the truss rod and intonation. A few other tweaks. But, overall it worked out. It is not the shredding machine it used to be. Though I can still rip pretty good on it.
I use the S2170 prestige for that anyway.
I already picked up half of the disturbed...the sickness album. That's it for now. I gotta go re-fuel (food). Plus my wife is nagging... dinner is ready.
Thanks again, Rock on!!!
S-man is offline
addario exl , edge trem , equipped guitar , ernie ball , fixed bridge , guage strings , high strings , string guage , trem springs , truss rod , zakk wylde
MyHELP lack of good string muting is KILLLING ME!! - Fret ha Triangle Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 05-31-2005 07:57 AM
New JS Model Info - JS-2000CG mike777 Ibanez JEM, UV, JS & Other Signature Models 103 04-05-2002 05:50 PM
guage question - detuning & string guage yoni162 All Other Guitars (including Prestige) 7 03-04-2002 06:57 AM
locking nut tuning problem - string retaining bar all the wa utopia Archived Topics and Common Questions 14 10-15-2001 09:55 AM
locking nut tuning problem - string retaining bar all the wa utopia Tech: Setup, Repairs and Mods 12 02-16-2001 01:07 AM
