Drop Tune String Size Help - Jemsite
post #1 of 6 (permalink) Old 01-16-2006, 09:26 AM Thread Starter
I want to tune me RG570 a whole step down to D standard as a lot of the music our band plays is in D Standard. Will 10-46 strings be big enough to provide enough resistance with the trem?
Thrash is offline
post #2 of 6 (permalink) Old 01-16-2006, 10:21 AM
Re: Drop Tune String Size Help
that is fine. 10-46 will "feel" like 9-42 in whole step down. don't forget about the setup, tho. if it has a trem, you will need to adjust the springs. as for the rest of the guitar, you may have to adjust the truss rod, and definitely the intonation.
rich
rty13ibz98 is offline
post #3 of 6 (permalink) Old 01-16-2006, 11:49 AM
D standard, as in DGCFAD? 46's are good enough. Definitely. Using a thicker gauge, maybe 48, can make it sound more aggresive and heavier, but 46's for D tuning, IMO, allows you to play easier. So you don't have to get sore fingertips after playing thick gauges for some time
aj_foes is offline
post #4 of 6 (permalink) Old 01-16-2006, 12:22 PM
For D Standard, 10's are fine yeah. Any tuning lower than that, and you really will be needing 11's. I like to shove on 11's anyway - that way it gives you the freedom to do whatever. I have never gone to 12's though, I have always felt that 11's were thick enough for me. But its all personal.
the.godfather is offline
post #5 of 6 (permalink) Old 01-16-2006, 01:07 PM
For a whole step down, I would personally use 11s, but then I like the feel of 10s in standard so to each their own.
lyconxero is offline
post #6 of 6 (permalink) Old 01-16-2006, 02:25 PM
May I suggest 10-52s?
red5 is offline
truss rod
Drop-Tune String Gauge - What do you use? bob oakman All Other Guitars (including Prestige) 15 07-01-2014 09:20 AM
drop d string size question asix Tech: Setup, Repairs and Mods 1 05-31-2013 05:42 PM
WTS Morpheus Drop Tune Pedal fluid1993 Classified Ads: Guitars and Gear 0 10-09-2011 06:33 PM
can you drop C tune a ZR equipped guitar? GODRAW All Other Guitars (including Prestige) 17 06-17-2010 01:31 AM
How did Steve Vai tune to Drop D on Bad Horsie - Isn`t that MrNiceguy87 Ibanez JEM, UV, JS & Other Signature Models 6 02-07-2002 04:54 PM
